Hobbywing Quattro ESC Arduino Pins
I have purchased the following Hobbywing Quattro ESC and I plan on using it with an Arduino Uno:
http://www.hobbyking.com/hobbyking/store/uploads/934316348X1085196X31.pdf
It has 4 speed controllers as a single unit and the connections for controlling the motors are a bit weird.
-The 1st connector has black, red and white -2nd has only yellow -3rd has only red -4th has only brown
How on earth do I connect this to the Arduino Uno pins?
Thanks,
Calum
On the first connector:
black -> Arduino GND white -> Arduino pin for channel 3
others: red -> Ardiuno pin for channel 1 yellow -> Arduino pin for channel 2 brown -> Arduino pin for channel 4
Use the Servo library, four instances.
Incidentally it may look like a neat idea to have 4 ESCs in one, but actually its not really:
o If it blows you have to replace whole unit (yes ESCs do fail)
o You can't put it in the down-wash from the rotors for cooling so its more likely to overheat
o All the high switching currents to the motors are brought to the centre of the craft causing a lot more interference to any sensors and the receiver.
o You need more high current wiring since 3 wires have to go to each corner, not 2 (or even 1 if you use aluminium frame as ground return).
