Hochladefehler/ Uploadproblem
Code unten/Code Belowe
Arduino Mega ist angeschlossen und On und L Lampe leuchten dauerhaft.
Versuche die Blinkdatei hochzuladen aber dann kommt folgender Fehler "Beim Hochladen des Sketches ist ein Fehler aufgetreten" würde mich freuen wenn jemand eine Idee hat. Port ist COM6.
lg
Globale Variablen verwenden 9 Bytes (0%) des dynamischen Speichers, 8183 Bytes für lokale Variablen verbleiben. Das Maximum sind 8192 Bytes.
Please do this:
  • (In the Arduino IDE) File > Preferences
  • Uncheck the checkbox next to “Show verbose output during: compilation”
  • Check the checkbox next to "Show verbose output during: upload
  • Click “OK”
  • Sketch > Upload
  • After the upload fails, you’ll see a button on the right side of the orange bar “Copy error messages” (or the icon that looks like two pieces of paper at the top right corner of the black console window in the Arduino Web Editor). Click that button.
  • In a forum reply here, click on the reply field.
  • Click the </> button on the forum toolbar. This will add the forum’s code tags markup to your reply.
  • Press “Ctrl + V”. This will paste the upload output between the code tags.
  • Move the cursor outside of the code tags before you add any additional text to your reply.
@BiMa93
if you would like your post moved please use the "report to moderator" option
Now I got this Massage
Right now I got get it. It is and Origanl Adurio bought 1 week ago O.O
Arduino: 1.8.12 (Windows 10), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Der Sketch verwendet 1456 Bytes (0%) des Programmspeicherplatzes. Das Maximum sind 253952 Bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega2560 -cwiring -PCOM6 -b115200 -D -Uflash:w:C:\Users\AppData\Local\Temp\arduino_build_362843/Blink.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM6
Using Programmer : wiring
Overriding Baud Rate : 115200
Is that the full output? Usually we would expect to see some error messages.
