Los dos codigos en cuestion
This is a library for the BMP280 humidity, temperature & pressure sensor
Designed specifically to work with the Adafruit BMP280 Breakout
----> Adafruit BMP280 I2C or SPI Barometric Pressure & Altitude Sensor [STEMMA QT] : ID 2651 : $9.95 : Adafruit Industries, Unique & fun DIY electronics and kits
These sensors use I2C or SPI to communicate, 2 or 4 pins are required
to interface.
Adafruit invests time and resources providing this open source code,
please support Adafruit andopen-source hardware by purchasing products
from Adafruit!
Written by Limor Fried & Kevin Townsend for Adafruit Industries.
BSD license, all text above must be included in any redistribution
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_BMP280.h>
#define BMP_SCK (13)
#define BMP_MISO (12)
#define BMP_MOSI (11)
#define BMP_CS (10)
int paquet=0;
Adafruit_BMP280 bmp; // I2C
//Adafruit_BMP280 bmp(BMP_CS); // hardware SPI
//Adafruit_BMP280 bmp(BMP_CS, BMP_MOSI, BMP_MISO, BMP_SCK);
while ( !Serial ) delay(100); // wait for native usb
Serial.println(F("BMP280 test"));
unsigned status;
//status = bmp.begin(BMP280_ADDRESS_ALT, BMP280_CHIPID);
status = bmp.begin(0x77);
if (!status) {
Serial.println(F("Could not find a valid BMP280 sensor, check wiring or "
"try a different address!"));
Serial.print("SensorID was: 0x"); Serial.println(bmp.sensorID(),16);
Serial.print(" ID of 0xFF probably means a bad address, a BMP 180 or BMP 085\n");
Serial.print(" ID of 0x56-0x58 represents a BMP 280,\n");
Serial.print(" ID of 0x60 represents a BME 280.\n");
Serial.print(" ID of 0x61 represents a BME 680.\n");
while (1) delay(10);
/* Default settings from datasheet. /
bmp.setSampling(Adafruit_BMP280::MODE_NORMAL, / Operating Mode. /
Adafruit_BMP280::SAMPLING_X2, / Temp. oversampling /
Adafruit_BMP280::SAMPLING_X16, / Pressure oversampling /
Adafruit_BMP280::FILTER_X16, / Filtering. /
Adafruit_BMP280::STANDBY_MS_500); / Standby time. */
paquet++;
Serial.print(paquet);
Serial.print(F(","));
Serial.print(bmp.readTemperature());
Serial.print(bmp.readPressure());
Serial.print(bmp.readAltitude(1013.25));
delay(2000);
// Basic demo for accelerometer readings from Adafruit MPU6050
#include <Adafruit_MPU6050.h>
#include <Adafruit_Sensor.h>
#include <Wire.h>
Adafruit_MPU6050 mpu;
void setup(void) {
while (!Serial)
delay(10); // will pause Zero, Leonardo, etc until serial console opens
Serial.println("Adafruit MPU6050 test!");
// Try to initialize!
if (!mpu.begin()) {
Serial.println("Failed to find MPU6050 chip");
while (1) {
delay(10);
Serial.println("MPU6050 Found!");
mpu.setAccelerometerRange(MPU6050_RANGE_8_G);
Serial.print("Accelerometer range set to: ");
switch (mpu.getAccelerometerRange()) {
case MPU6050_RANGE_2_G:
Serial.println("+-2G");
case MPU6050_RANGE_4_G:
Serial.println("+-4G");
case MPU6050_RANGE_8_G:
Serial.println("+-8G");
case MPU6050_RANGE_16_G:
Serial.println("+-16G");
mpu.setGyroRange(MPU6050_RANGE_500_DEG);
Serial.print("Gyro range set to: ");
switch (mpu.getGyroRange()) {
case MPU6050_RANGE_250_DEG:
Serial.println("+- 250 deg/s");
case MPU6050_RANGE_500_DEG:
Serial.println("+- 500 deg/s");
case MPU6050_RANGE_1000_DEG:
Serial.println("+- 1000 deg/s");
case MPU6050_RANGE_2000_DEG:
Serial.println("+- 2000 deg/s");
mpu.setFilterBandwidth(MPU6050_BAND_21_HZ);
Serial.print("Filter bandwidth set to: ");
switch (mpu.getFilterBandwidth()) {
case MPU6050_BAND_260_HZ:
Serial.println("260 Hz");
case MPU6050_BAND_184_HZ:
Serial.println("184 Hz");
case MPU6050_BAND_94_HZ:
Serial.println("94 Hz");
case MPU6050_BAND_44_HZ:
Serial.println("44 Hz");
case MPU6050_BAND_21_HZ:
Serial.println("21 Hz");
case MPU6050_BAND_10_HZ:
Serial.println("10 Hz");
case MPU6050_BAND_5_HZ:
Serial.println("5 Hz");
Serial.println("");
delay(100);
/* Get new sensor events with the readings */
sensors_event_t a, g, temp;
mpu.getEvent(&a, &g, &temp);
/* Print out the values */
Serial.print("Acceleration X: ");
Serial.print(a.acceleration.x);
Serial.print(", Y: ");
Serial.print(a.acceleration.y);
Serial.print(", Z: ");
Serial.print(a.acceleration.z);
Serial.println(" m/s^2");
Serial.print("Rotation X: ");
Serial.print(g.gyro.x);
Serial.print(g.gyro.y);
Serial.print(g.gyro.z);
Serial.println(" rad/s");
Serial.print("Temperature: ");
Serial.print(temp.temperature);
Serial.println(" degC");
Serial.println("");
