hey...i want to control the position of the servo motor...i want it to turn then hold the position..but why the servo keep turn back to 0 degree then rotate it back.
here the coding
// Controlling a servo position using a potentiometer (variable resistor)
// by Michal Rinott <http://people.interaction-ivrea.it/m.rinott>
#include <Servo.h>
Servo myservo; // create servo object to control a servo
// analog pin used to connect the potentiometer
int val; // variable to read the value from the analog pin
myservo.attach(9); // attaches the servo on pin 9 to the servo object
val=140; // scale it to use it with the servo (value between 0 and 180)
myservo.write(val); // sets the servo position according to the scaled value
delay(15); // waits for the servo to get there
how to make the servo hold the postion and never rotate it back?
Some servo test code you can try to see if the servo behaves the same.
// zoomkat 10-4-10 serial servo test
// type servo position 0 to 180 in serial monitor
// for writeMicroseconds, use a value like 1500
// for IDE 0019 and later
// Powering a servo from the arduino usually DOES NOT WORK.
String readString;
#include <Servo.h>
myservo.attach(7); //the pin for the servo control
Serial.println("servo-test-21"); // so I can keep track of what is loaded
while (Serial.available()) {
delay(1);
if (Serial.available() >0) {
char c = Serial.read(); //gets one byte from serial buffer
readString += c; //makes the string readString
if (readString.length() >0) {
Serial.println(readString); //so you can see the captured string
int n;
char carray[6]; //converting string to number
readString.toCharArray(carray, sizeof(carray));
n = atoi(carray);
myservo.writeMicroseconds(n); // for microseconds
//myservo.write(n); //for degees 0-180
readString="";
thanks all..and Nick Gammon
it seem my hardware have the problem..when i try it using my MEGA it work perfectly, but when i try it on my Duemilanove the problem occur.
i think the problem is on my duemilanove
