Hi there.
I'm using a SIM900 with a Hologram SIM to send sensor data to a website.
The data send is fine, but when I try to have an hour delay in between data sends, the SIM disconnects at the end of the hour instead of uploading the new data.
When I do a delay of 10 minutes, it works fine.
Any ideas what to change? Thanks.
Code:
#include <SoftwareSerial.h>
SoftwareSerial gprsSerial(10, 11);
#include <String.h>
#include "DHT.h"
#define DHTPIN 2 // Digital pin connected to the DHT sensor
#define DHTTYPE DHT11 // DHT 11
DHT dht(DHTPIN, DHTTYPE); // Setup DHT
#define soilPin A0 // define the soil pin for reading soil data
float soilValue = 0; // the value for the soil sensor (used in the loop)
dht.begin(); // begin dht
gprsSerial.begin(9600);
Serial.println("Config SIM900...");
delay(2000);
Serial.println("Done!...");
gprsSerial.flush();
Serial.flush();
//delay(10000);
// bearer settings
gprsSerial.println("AT+SAPBR=0,1");
delay(2000);
toSerial();
// attach or detach from GPRS service
gprsSerial.println("AT+CGATT?");
delay(100);
toSerial();
// bearer settings
gprsSerial.println("AT+SAPBR=3,1,\"CONTYPE\",\"GPRS\"");
delay(2000);
toSerial();
// bearer settings
gprsSerial.println("AT+SAPBR=3,1,\"APN\",\"hologram\"");
delay(2000);
toSerial();
// strength
gprsSerial.println("AT+CSQ ");
delay(2000);
toSerial();
// bearer settings
gprsSerial.println("AT+SAPBR=1,1");
delay(2000);
toSerial();
GET TEMPERATURE AND HUMIDITY
float h = dht.readHumidity();
float t = dht.readTemperature(true);
float f = dht.computeHeatIndex(t, h);
FIND SOIL MOISTURE AVERAGE FOR BEST RESULT
for (int i = 0; i <= 100; i++)
soilValue = soilValue + map(analogRead(soilPin), 0, 1023, 100, 0); //convert reading to %
delay(1);
float m = soilValue = soilValue / 100.0;
Serial.print("Hum: "+String(h)+"\n temp: "+String(t)+"\n moist: "+String(m)+"\n heat index: "+String(f)+"\n");
// initialize http service
gprsSerial.println("AT+HTTPINIT");
delay(2000);
toSerial();
// set http param value
gprsSerial.println("AT+HTTPPARA=\"URL\",\"http://api.jackhaegele.com/fielded-api.php?t=" + String(t) + "&m=" + String(m) + "&h=" + String(h) + "&f=" + String(f) + "\"");
delay(6000);
toSerial();
// set http action type 0 = GET, 1 = POST, 2 = HEAD
gprsSerial.println("AT+HTTPACTION=0");
delay(6000);
toSerial();
// read server response
gprsSerial.println("AT+HTTPREAD");
toSerial();
gprsSerial.println("");
gprsSerial.println("AT+HTTPTERM");
toSerial();
delay(300);
delay (60UL * 60UL * 1000UL);
void toSerial()
while (gprsSerial.available() != 0)
Serial.write(gprsSerial.read());
