So I am working on implementing this home automation sketch, and for some reason when i add the 2 commented client.println lines the arduino will not initialize the webserver. it compiles right but will not work.
(i know i dont have any actual IR codes or anything implemented but i just want to get the webpage to serve up right.
looking for any advice
thanks!
#include <Dhcp.h>
#include <Dns.h>
#include <Ethernet.h>
#include <EthernetClient.h>
#include <EthernetServer.h>
#include <EthernetUdp.h>
#include <util.h>
#include <SPI.h>
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //I left the MAC address and IP address blank.
byte ip[] = {192,168,1,177 }; // You will want to fill these in with your MAC and IP address.
EthernetServer server(80); // Assigning the port forwarded number. It's almost always 80.
String readString; // We will be using strings to keep track of things.
int LivingRoomLight = 9;
#define W5200_CS 10
#define SDCARD_CS 4
pinMode(SDCARD_CS,OUTPUT);
digitalWrite(SDCARD_CS,HIGH);//Deselect the SD card
// start the Ethernet connection and the server:
pinMode(LivingRoomLight, OUTPUT);
Ethernet.begin(mac, ip);
Serial.println("Ethernet Begun");
void loop(){
if (client) {
while (client.connected()) {
if (client.available()) { // This is all where we start up the server and strings.
char c = client.read();
if (readString.length() < 100) {
readString += c;
if (c == '\n') {
Serial.println(readString); // And here we begin including the HTML
client.println("<!DOCTYPE html PUBLIC '-//W3C//DTD HTML 4.01//EN'>");
client.println("<html>");
client.println("<head>");
client.println("<meta name='viewport' content='width=device-width, initial-scale=1.0'>");
client.println("<title>");
client.println("Blajda Home Automation");
client.println("</title>");
client.println("<link rel='stylesheet' type='text/css' href='http://www.ryanblajda.com/wp-content/uploads/2014/09/webserver.css'/>");
client.println("</head>");
client.println("<body>");
client.println("<center>");
client.println("<h2 class='section'><a href='http://192.168.1.177'>Home</a></h2>");
client.println("<h2 class='section'><a href='#lighting'>Lighting</a></h2>");
client.println("<h2 class='section'><a href='#ir'>IR Control</a></h2>");
client.println("<div id='content'>");
client.println("<h2><a id='lighting'>Lighting</a></h2>");
client.println("<h3>Living Room</h3>");
client.println("Light 1 <input class='left' type='submit' value='Off' onClick=window.location='/?livinglightoff1\'><input class='right' type='submit' value='On' onClick=window.location='/?livinglighton1\'>");
client.println("<h3>Bedroom</h3>");
client.println("Light 1 <input class='left' type='submit' value='Off' onClick=window.location='/?bedlightoff1\'><input class='right' type='submit' value='On' onClick=window.location='/?bedlighton1\'>");
client.println("<h2><a id='ir'>IR Control</a></h2>");
client.println("<h3>Projector</h3>");
client.println("Power <input class='left' type='submit' value='Off' onClick=window.location='/?projectoroff\'><input class='right' type='submit' value='On' onClick=window.location='/?projectoron\'>");
client.println("
client.println("<h3>Apple TV</h3>");
//client.println("<input class='left' type='submit' value='Up' onClick=window.location='/?appletvup\'><input class='right' type='submit' value='Down' onClick=window.location='/?appletvdown\'>");
//client.println("<input class='left' type='submit' value='Left' onClick=window.location='/?projectorleft\'><input class='right' type='submit' value='Right' onClick=window.location='/?projectorright\'>");
client.println("</div>");
client.println("</body>");
client.println("</html>");
delay(1);
if (readString.indexOf("?livinglighton1") > 0) {
digitalWrite(9, HIGH);
Serial.println("On");
else {
if (readString.indexOf("?livinglightoff1") > 0) {
digitalWrite(9, LOW);
Serial.println("Off");
readString="";
client.stop(); // End of session.
An example of a lot of static html bundled inside the F() macro to save memory.
//double quote " in html replaced with a single quote' to prevent compile error
//html lines consolidated and put inside F() macro to save memory space
client.print(F("<html><head><meta http-equiv='Content-Language' content='pt-br'>"
"<meta http-equiv='Content-Type' content='text/html; charset=windows-1252'>"
"<title>Unirp - Centro Universitário de Rio Preto</title></head><body>"
"<div align='center'><h1>Centro Universitario de Rio Preto</h1>"
"<h2>Gerenciamento de Volume e Temperatura da Banheira</h2></div>"
"<div align='center'><h4> Pressione o Botão para encher na temperatura desejada</h4>"
"<table border='0' width='50%' cellpadding='2'><tr></tr><tr><td>"
"<!--Botão Temperatura Fria--><form method='POST' action='arduino.php'>"
"<p align='center'><input type='hidden' value='fria' name='tempD' >"
"<input type='submit' value='Água Fria' name='fria'></p></form>"
"<!--Botão Temperatura Morna--><form method='POST' action='arduino.php'>"
"<p align='center'><input type='hidden' value='morna' name='tempD' >"
"<input type='submit' value='Água Morna' name='morna'></p></form>"
"<!--Botão Temperatura Quente--><form method='POST' action='arduino.php'>"
"<p align='center'><input type='hidden' value='quente' name='tempD' >"
"<input type='submit' value='Água Quente' name='quente'></p></form></form>"
"<div align='center'></div></tr></table></div></body></html>"));
i tried adding that, and it didnt work, i only saw text it wouldnt render as actual HTML
So, you changed your code, and didn't show it to us. You ran the code, and saw some results, which you didn't share. And, yet, you still expect us to help you fix your code. Give that some thought, and I'm willing to bet that the next step occurs to you, sooner or later.
#include <Dhcp.h>
#include <Dns.h>
#include <util.h>
#include <SPI.h>
#define W5200_CS 10
#define SDCARD_CS 4
void loop(){
if (client) {
readString += c;
if (c == '\n') {
client.println(F("<!DOCTYPE html PUBLIC '-//W3C//DTD HTML 4.01//EN'>"
"<html>"
"<head>"
"<title>"
"</title>"
"</head>"
"<body>"
"<center>"
"<div class='accordion'>"
"<div id='tab-0'>"
"<a href='http://192.168.1.177' class='tab'>Home</a>"
"</div><!--tab0-->"
"<div id='tab-1'>"
"<a href='#tab-1' class='tab'>Lighting</a>"
"<div class='content'>"
"Living Room 1 <input class='left' type='submit' value='Off' onClick=window.location='/?livinglightoff1#tab-1\'><input class='right' type='submit' value='On' onClick=window.location='/?livinglighton1#tab-1\'>"
"</div><!--content-->"
"</div><!--tab1-->"
"<div id='tab-2'>"
"<a href='#tab-2' class='tab'>IR Control</a>"
"Projector"
"<input class='left' type='submit' value='Off' onClick=window.location='/?projectoroff#tab-2\'><input class='right' type='submit' value='On' onClick=window.location='/?projectoron#tab-2\'>"
//client.println("<input class='center' type='submit' value='Up' onClick=window.location='/?projectorup#tab-2\'>");
//client.println("
//client.println("<input class='left' type='submit' value='Left' onClick=window.location='/?projectorleft#tab-2\'><input class='right' type='submit' value='Right' onClick=window.location='/?projectorright#tab-2\'>");
//client.println("
//client.println("<input class='left' type='submit' value='Down' onClick=window.location='/?projectordown#tab-2\'>");
"</div><!--tab2-->"
"</div>"
"</center>"
"</body>"
"</html>"));
delay(1);
else {
readString="";
Your code includes libraries and such that i don't see a need for. Below is some server test code that works on my setup. You can try it and see if it works in your setup. The below code doesn't include disabling an SD card if inserted, so remove the SD card if inserted. You can open the serial monitor and see the commands received by the arduino.
//zoomkat 8-04-12
//simple button GET server code to control servo and arduino pins 5, 6, and 7
//for use with IDE 1.0
//open serial monitor to see what the arduino receives
//use ' instead of " in the html
//address will look like http://192.168.1.102:84 when submited
//for use with W5100 based ethernet shields
///note that the below bug fix may be required
// http://code.google.com/p/arduino/issues/detail?id=605
#include <SPI.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 102 }; // ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port
String readString;
void setup(){
pinMode(5, OUTPUT); //pin selected to control
pinMode(6, OUTPUT); //pin selected to control
pinMode(7, OUTPUT); //pin selected to control
pinMode(8, OUTPUT); //pin selected to control
//start Ethernet
Ethernet.begin(mac, ip, gateway, gateway, subnet);
server.begin();
//enable serial data print
Serial.println("server multi pin button test 1.0"); // so I can keep track of what is loaded
void loop(){
// Create a client connection
if (client) {
//read char by char HTTP request
//store characters to string
readString += c;
//Serial.print(c);
//if HTTP request has ended
if (c == '\n') {
Serial.println(readString); //print to serial monitor for debuging
client.println("HTTP/1.1 200 OK"); //send new page
client.println("Content-Type: text/html");
client.println();
client.println("<HTML>");
client.println("<HEAD>");
client.println("<TITLE>Arduino GET test page</TITLE>");
client.println("</HEAD>");
client.println("<BODY>");
client.println("<H1>Zoomkat's simple Arduino button</H1>");
// For simple testing, pin 5, 6, 7, and 8 are used in buttons
// DIY buttons
client.println("<a href=/?on2 >ON</a>");
client.println("<a href=/?off3 >OFF</a>");
client.println(" <a href=/?off3579 >ALL OFF</a>
// mousedown buttons
client.println("<input type=button value=ON onmousedown=location.href='/?on4'>");
client.println("<input type=button value=OFF onmousedown=location.href='/?off5'>");
client.println(" <input type=button value='ALL OFF' onmousedown=location.href='/?off3579'>
// mousedown radio buttons
client.println("<input type=radio onmousedown=location.href='/?on6'>ON</>");
client.println("<input type=radio onmousedown=location.href='/?off7'>OFF</>");
client.println(" <input type=radio onmousedown=location.href='/?off3579'>ALL OFF</>
// custom buttons
client.print("<input type=submit value=ON style=width:100px;height:45px onClick=location.href='/?on8'>");
client.print("<input type=submit value=OFF style=width:100px;height:45px onClick=location.href='/?off9'>");
client.print(" <input type=submit value='ALL OFF' style=width:100px;height:45px onClick=location.href='/?off3579'>");
client.println("</BODY>");
client.println("</HTML>");
delay(1);
//stopping client
client.stop();
///////////////////// control arduino pin
if(readString.indexOf('2') >0)//checks for 2
digitalWrite(5, HIGH); // set pin 5 high
Serial.println("Led 5 On");
if(readString.indexOf('3') >0)//checks for 3
digitalWrite(5, LOW); // set pin 5 low
Serial.println("Led 5 Off");
if(readString.indexOf('4') >0)//checks for 4
digitalWrite(6, HIGH); // set pin 6 high
Serial.println("Led 6 On");
if(readString.indexOf('5') >0)//checks for 5
digitalWrite(6, LOW); // set pin 6 low
Serial.println("Led 6 Off");
if(readString.indexOf('6') >0)//checks for 6
digitalWrite(7, HIGH); // set pin 7 high
Serial.println("Led 7 On");
if(readString.indexOf('7') >0)//checks for 7
digitalWrite(7, LOW); // set pin 7 low
Serial.println("Led 7 Off");
if(readString.indexOf('8') >0)//checks for 8
digitalWrite(8, HIGH); // set pin 8 high
Serial.println("Led 8 On");
if(readString.indexOf('9') >0)//checks for 9
digitalWrite(8, LOW); // set pin 8 low
Serial.println("Led 8 Off");
//clearing string for next read
readString="";
since i have a shield with the w5200 wiznet chip i have to disable the SD card if its not in use or the ethernet will not enable at all.
also if you dont mind lending any other advice, i was trying to modify my code so that it would print the On button when the light is off, and the Off Button when the light is on, but it seems i cannot get it to work...
It is unlikely that analogRead(), which reads an analog pin, is going to return 1. If, indeed, a digital device is attached to it, the reading is more likely to be 0 or 1022+.
Earlier, it was suggested that you might be running out of memory, and yet here are MORE string literals in SRAM. Have you measured how much free memory you have?
I don't have an ethernet shield with the w5200 chip, but with the w5100 chip the SD card disable is only required if an SD card is actually inserted in the SD card slot. If you have an SD card in the SD slot, remove it for the code I posted. Your code may have other issues.
the only way i got the shield to work was with a modified version of the Ethernet library and disabling the SD Card when its not in use. It should not be impeding anything else.
unrelated to the SD card and SRAM issues
even with digitalRead it wont print the else statement.... GAAAHH
#include <SPI.h>
byte mac[] = {
byte ip[] = {
#define W5200_CS 10
#define SDCARD_CS 4
digitalWrite(LivingRoomLight, LOW);
void loop(){
if (client) {
readString += c;
if (c == '\n') {
client.println("<div class='accordion'>");
client.println("<div id='tab-0'>");
client.println("<a href='http://192.168.1.177' class='tab'>Home</a>");
client.println("</div><!--tab0-->");
client.println("<div id='tab-1'>");
client.println("<a href='#tab-1' class='tab'>Lighting</a>");
client.println("<div class='content'>");
if (digitalRead(LivingRoomLight) == LOW) {
client.println("Living Room 1 <input class='left' type='submit' value='On' onClick=window.location='/?livinglighton1#tab-1\'>");
//Serial.println(digitalRead(LivingRoomLight));
else {
client.println("Living Room 1 <input class='right' type='submit' value='On' onClick=window.location='/?livinglightoff1#tab-1\'>");
else {
client.println("</div><!--content-->");
client.println("</div><!--tab1-->");
client.println("<div id='tab-2'>");
client.println("<a href='#tab-2' class='tab'>IR Control</a>");
client.println("Projector");
client.println("
client.println("<input class='left' type='submit' value='Off' onClick=window.location='/?projectoroff#tab-2\'><input class='right' type='submit' value='On' onClick=window.location='/?projectoron#tab-2\'>");
client.println("
//client.println("
//client.println("
client.println("</div><!--tab2-->");
client.println("</center>");
delay(1);
/*if (readString.indexOf("?livinglighton1") > 0) {
else {
readString="";
I just want to point out that this text has no newlines in it. However I tested that as a web page and it seemed to work without them.
the only reason i asked the if then question was because I could not get the client.println(F(""); to work and wanted to work on something else.
What do you mean by that? The code you posted compiled OK for me.
and it didnt work
You need to be a lot more specific than say things "don't work" or not. Don't compile? Return unexpected results? If so, what results? Copy and paste or screenshot.
I printed your text to the serial monitor, saved to a disk file (test.html) and it opened up showing your buttons. So the problem is not with the HTML.
You might need a HTTP header sent first, or it will interpret the rest as pure text.
