Home Automation System Problems Keeps disconnecting
Hello Guyz,
I have written a code to start my home generator automatically and with blynk on mobile but it keeps disconnecting . code is attached.
when i press a button in the app the esp disconnects gives the error related to high ping
[43557] Ready (ping: 36022ms).
AT+CIPSEND=1,40
AT+CIPCLOSE=1
[69321] Login timeout
AT+CIPCLOSE=1
#define BLYNK_PRINT Serial
#include <ESP8266_Lib.h>
#include <BlynkSimpleShieldEsp8266.h>
char auth[] = "0e305d6b5b2e42bfb7ce2116dbf99b05";
char ssid[] = "PTCL-BB";
char pass[] = "3553C8A8";
#define ESP8266_BAUD 115200
ESP8266 wifi(&Serial);
// Out For Relays //
int GPR    = 6;
int GSR    = 7;
int COO    = 8;
// Digital Read Relays //
int ACCP      = 9;
int GENP      = 10;
int UPSP      = 11;
int UPSBPP    = 12;
int ACC;
int GENS;
int UPS;
int UPSBP;
// Variables //
int TATP     = 4;
int ATP      = 0;
int COS      = 0;
long int DT  = 60000;
// Mobile Buttons //
int GONM   = 0;
int GOFM   = 0;
int ATS    = 1;
int CONM   = 0;
int COFM   = 0;
int UPSBPM = 0;
 // Debug console
 delay(10);
 // Set ESP8266 baud rate
 Serial.begin(ESP8266_BAUD);
 delay(10);
 Blynk.begin(auth, wifi, ssid, pass);
 pinMode(GPR, OUTPUT);
 pinMode(GSR, OUTPUT);
 pinMode(COO, OUTPUT);
 pinMode(ACCP, INPUT);
 pinMode(GENP, INPUT);
 pinMode(UPSP, INPUT);
 pinMode(UPSBPP, INPUT);
 digitalWrite(GPR, HIGH);
 digitalWrite(GSR, HIGH);
 digitalWrite(COO, HIGH);
void generatorstart(){
if (ATP <= TATP){
ATP = ATP + 1;
Serial.println("");
Serial.println("Generator Starting!!!");
digitalWrite(GPR,  LOW);
digitalWrite(GSR,  LOW);
delay(3000);
Serial.println("Attempted!!!");
Serial.println("");
delay(15000);
Serial.println(ATP);
Serial.println("");
Serial.println("Already attempted 4 times");
Serial.println("Generator Will Not Start Until Reset");
Serial.println("");
delay(10);
void generatoroff(){
Serial.println("");
Serial.println("Generator Shutting Down!!!");
void changeoveron(){
  Serial.println("COO Over on Routine");
  delay(DT);
  digitalWrite(COO,LOW);
  COS=COS+1;
void changeoveroff(){
  Serial.println("COO Over off Routine");
  delay(DT/2);
  digitalWrite(COO,HIGH);
  COS=COS-1;
void logics(){
if ( ACC == 0 && (UPSBP == 1 || UPSBPM == 1) && GOFM == 0 && GENS == 0){
Serial.println("");
Serial.println("WAPDA IS OFFLINE!");
Serial.println("UPS IS BYPASSED");
Serial.println("Starting Generator.");
generatorstart();
Serial.println("");
if ( ACC == 0 && UPS == 0 && GOFM == 0 && GENS == 0){
Serial.println("");
Serial.println("UPS IS NOT BYPASSED");
Serial.println("UPS IS DISCHARGED");
generatorstart();
Serial.println("");
if ( ACC == 0 && (UPSBP == 1 || UPSBPM == 1) && GOFM == 0 && GENS == 1){
Serial.println("");
Serial.println(" Generator Started Sucessfully!!");
Serial.println("Now System Will Reset Number of Attempts");
ATP=0;
Serial.println("");
Serial.println("Now System will run Change Over Routine");
if (COS == 0){
  changeoveron();
if ( ACC == 0 && UPS == 0 && GOFM == 0 && GENS == 1){
Serial.println("");
ATP=0;
Serial.println("");
if (COS == 0){
  changeoveron();
if ( ACC == 1 && GONM == 0 && GENS == 1){
Serial.println("");
Serial.println("WAPDA IS NOW ONLINE");
Serial.println("GENERATOR WILL NOW STOP");
if (COS == 1){
  changeoveroff();
generatoroff();
if ( ACC == 0 && UPS == 1 && UPSBP == 0 && UPSBPM == 0 && GONM == 0 && GENS == 1){
Serial.println("");
Serial.println("UPS IS NOW ONLINE");
if (COS == 1){
  changeoveroff();
generatoroff();
if ( ACC == 1 && GONM == 0 && GENS == 0){
Serial.println("");
Serial.println("GENERATOR IN NOW SUCESSFULLY STOPPED");
if (COS == 1){
  changeoveroff();
Serial.println("");
Serial.println("CHANGE OVER ROUTINE SUCESSFULL");
if ( ACC == 0 && UPS == 1 && UPSBP == 0 && UPSBPM == 0 && GONM == 0 && GENS == 0){
Serial.println("");
if (COS == 1){
  changeoveroff();
Serial.println("");
void overrides(){
if ( GONM == 1 && GOFM == 0 && GENS == 0){
Serial.println("");
Serial.println("Mobile Over-Ride Activated!!");
Serial.println("Warning Generator will Not Stop Automatically!");
generatorstart();
Serial.println("");
if ( GONM == 1 && GOFM == 0 && GENS == 1){
Serial.println("");
ATP=0;
Serial.println("");
if (COS == 0){
  changeoveron();
if ( GOFM == 1 && GENS == 1){
Serial.println("");
Serial.println("MOBILE OVERRIDE");
if (COS == 1){
  changeoveroff();
generatoroff();
if ( GOFM == 1 && GENS == 0){
Serial.println("");
if (COS == 1){
  changeoveroff();
Serial.println("");
if ( CONM == 1 && COFM == 0){
Serial.println("");
Serial.println("INIATING CHANGEOVER ON ROUTINE");
Serial.println("Warning CHANGEOVER will Not TURN OFF Automatically!");
generatorstart();
Serial.println("");
if (COS == 0){
  changeoveron();
Serial.println("");
if ( CONM == 0 && COFM == 1){
Serial.println("");
Serial.println("INIATING CHANGEOVER OFF ROUTINE");
Serial.println("Warning CHANGEOVER will Not TURN ON Automatically!");
generatorstart();
Serial.println("");
if (COS == 1){
  changeoveroff();
Serial.println("");
void readings(){
ACC = digitalRead(ACCP);
GENS = digitalRead(GENP);
UPS = digitalRead(UPSP);
UPSBP = digitalRead(UPSBPP);
void ledsmobile(){
if (ACC == 1){
Blynk.virtualWrite(V7, 255);
Blynk.virtualWrite(V7, 0);
if (GENS == 1){
Blynk.virtualWrite(V8, 255);
Blynk.virtualWrite(V8, 0);
if (COS == 1){
Blynk.virtualWrite(V9, 255);
Blynk.virtualWrite(V9, 0);
if (UPS == 1){
Blynk.virtualWrite(V10, 255);
Blynk.virtualWrite(V10, 0);
Blynk.run();
if ( ATS == 1){
logics();
overrides();
readings();
ledsmobile();
BLYNK_WRITE(V1) {
 int pinValue = param.asInt();
 if (pinValue == 1) {
    ATS = 1;
    ATS = 0;
BLYNK_WRITE(V2) {
    UPSBPM = 1;
    UPSBPM = 0;
BLYNK_WRITE(V3) {
    GONM = 1;
    GONM = 0;
BLYNK_WRITE(V4) {
    GOFM = 1;
    GOFM = 0;
BLYNK_WRITE(V5) {
    CONM = 1;
    CONM = 0;
BLYNK_WRITE(V6) {
    COFM = 1;
    COFM = 0;
Your code is very hard to read and understand. I suggest you perform Auto-Format. Also variable names like UPSBP, UPSBPM & GONM may be meaningful to you, but not to others, so I suggest you change them to longer names that better indicate their purpose.
A schematic would help us understand the whole project.
Thanks for using code tags. +1 Karma
