Home automation system with WeMos Mini D1, ESPDuino ESP-13, and a laptop
Good morning!
I am developing a home automation system using the following setup:
The WeMos board calls WiFi.softAP() and is responsible for creating a specific WiFi network for the controlled power outlets. This board also has a web server.
The ESPduino board (Keyestudio ESP-13 Shield) is coupled with an Arduino Uno and is responsible for toggling the power outlets. This board has a web server.
Each board gets its IP Address via WeMos board’s DHCP server.
Then I try to connect to the WeMos board and to the ESPduino board using Chrome.
The first works whereas the latter doesn’t.
I used Wireshark sniffing on the network, and the ARP packets are circulating when I try and navigate to the ESPDuino web server.
Code for the hotspots:
#include <LiquidCrystal.h>
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
#define LCD_TIMEOUT      4000UL
#define HOTSPOT_TIMEOUT  10000L
char ssid[] = "Rainbow";
char pass[] = "myP@ssw0rd2";
int id = 1;
char name[] = "Lampada1";
ESP8266WebServer listener(80);
This is the usual layout:
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
The one below is when there is a ESP8266 shield
//LiquidCrystal lcd(8, 9, 6, 5, 3, 2);
unsigned long lcdRefresh = 0;
unsigned long hotspotRefresh = 0;
  //lcd.begin(16, 2);
  //lcd.autoscroll();
  pinMode(A0, OUTPUT);
  digitalWrite(A0, LOW);
  if (WiFi.status() == WL_NO_SHIELD) {
    Serial.println(F("Where is the WiFi module? HALT"));
    //lcd.setCursor(0, 0);
    //lcd.print(F("System halted   "));
    while (true);
  WiFi.disconnect();
  WiFi.begin(ssid, pass);
  //lcd.print(F("Warming up      "));
  Serial.println("Warming up");
  delay(10000);
  if (WiFi.waitForConnectResult() != WL_CONNECTED) {
    Serial.println(F("Could not find WiFi network! HALT"));
    while (true);
  Serial.println("Connected!");
  listener.on("/", HTTP_GET, []() {
    String result = String(F("{\"state\": ")) + (digitalRead(A0) == LOW ? "off" : "on") + "\"}";
    listener.send(200, "application/json", result);
  listener.on("/", HTTP_POST, []() {
    int state = digitalRead(A0);
    digitalWrite(A0, state = state == HIGH ? LOW : HIGH);
  listener.begin();
  Serial.print("My IP address: ");
  //lcd.print(WiFi.localIP());
  listener.handleClient();
  //checkDisplay();
  //updateServer();
void updateServer() {
  if (millis() - hotspotRefresh > HOTSPOT_TIMEOUT || millis() < lcdRefresh) {
    hotspotRefresh = millis();
    return;
  //lcd.setCursor(0, 1);
  //lcd.print(F("Hotspot refresh!"));
  WiFiClient client;
  if (client.connect(WiFi.gatewayIP(), 80)) {
    client.print(F("PUT /hotspots/"));
    client.print(id);
    client.print(F("/"));
    client.print(name);
    client.print(WiFi.localIP());
    client.println(F(" HTTP/1.1"));
    client.println(F("Connection: close"));
    client.println();
    client.stop();
void checkDisplay() {
  if (millis() - lcdRefresh > LCD_TIMEOUT || millis() < lcdRefresh) {
    lcdRefresh = millis();
    //lcd.print(F("                "));
