Im planning a home brew set up using 5 flow controlers (with mechanical ball valves) and 1 pump, the ball valves are 12v the pump is 12v 3a,
The process is
Fill tank 1 (HLT) with water (60l say)
once full transfer some water to tank 2 (MLT) (25l say)
then run a pump (at a set rate of 3lpm) wait,
then transfer water from tank 2 in to tank 3 (at a set rate) while transfering water from tank 1 to tank 2( at the same rate as tank 1 to tank),
wait then run water through a cooler while running water from tank 3 to tank 4
(all heating control will come from a bsc460)
I belive id need 3 motor shields to do this id like 3 (lcd) screens to monitor fill levels and flow rates
So my questons are can i run this with 1 uno (if all ball valves and pump are individually powered)
Can i run multiple shields from one uno
Can 1 uno run multiple motor shields
Can 1 uno run 1 screen and change the display as the process steps through (though to keep things simple i may use 3 unos)
TIA
Pete
