Home controller system on web page
hye guys, i dont event know what am i typing here but seems like i got prob with my arduino its either the board itself or the programming.. ok im now trying to develop the home controller which can control the light the fan and adding the additional feature for security which is PIR sensor and buzzer as alarm controll directly from web page using the html code. im using the Arduino uno r3 + Ethernet shield w5200 v1.0 . when ever i tried to compiled i got the error such as 'Ethernet' was not declared in this scope is it because i change the libraries from arduino ide w5100 to 5200.blur
#include <SPI.h>
#include <Ethernet.h>
//ethernet configuration
byte ip[] = { 192, 168, 0, 13};
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
EthernetServer server(27);
//initial
int LED=8; //led is connected to digital pin 4
int PIR=3; //PIR sensor is connected to digital pin 3
int LDR=5; //LDR sensor is connected to analog in 5
int LAMP=4; //LAMP is conected to digital pin 2
int FAN=9; //FAN is connected to digital pin 9
int BUZZER=2; //BUZZER is connected to digital pin 8
int PIRstate=0; //ariable for PIR sensor status
int lampstate=0; //variable for LAMP status
int fanstate=0; //ariable for FAN status
float photocell=0; //variable for photocell (LDR) analog value
char c=0; //received data
char command[2]= "\0"; //command
Ethernet.begin(mac, ip);
server.begin();
pinMode(LED,OUTPUT);
pinMode(LAMP,OUTPUT);
pinMode(PIR,INPUT);
pinMode(FAN,OUTPUT);
pinMode(BUZZER,OUTPUT);
EthernetClient client=server.available();
//detect if current is the first line
boolean current_line_is_first=true;
if(client)
//an http request ends with a blank line
boolean current_line_is_blank= true;
while (client.connected())
if (client.available())
char c=client.read();
//if we've gotten to the end of the line(receive a newline character)
//and the line is blank, the http request has ended,
//so we can send a reply
if(c=='\n'&&current_line_is_blank)
//send a standard http response header
client.println("Content-Type: text/html");
client.println();
client.println("");
//auto reload webpage every 5 second
client.println("<META HTTP-EQUIV=REFRESH CONTENT=5 URL=>");
//webpage title
client.println("");
client.println("
client.println("
WELCOME HOME!!
"); //read analog pin 1 for the alue of photocell photocell=analogRead(LDR); if(photocell<40) { digitalWrite(LED,HIGH); } else { digitalWrite (LED,LOW); } client.print("LDR SENSOR:
Light Intensity= "); client.println(photocell,2); client.println("
"); //read digital pin 13 for the state of PIR sensor client.println("SECURITY SYSTEM:"); client.println(""); client.println("PIR On"); client.println("PIR Off"); client.println(" ");
client.println("intruder detection=");
if(PIRstate==HIGH)//PIR sensor detected movement
client.println("Motion Detected!");
else //No movement is detected
client.println("No Movement");
if(PIRstate==HIGH)
unsigned char i;
for(i=0;i<25;i++)
digitalWrite(BUZZER,HIGH);
delay(100); //Delay 1ms
digitalWrite(BUZZER,LOW);
else // NO MOVEMENT IS DETECTED
client.println("
//button functions
client.println("APPLIANCES:
client.println("");
client.println("LAMP On");
client.println("LAMP Off");
client.println("");
client.println("FAN high");
client.println("FAN low");
client.println("FAN off");
client.println("
"); client.println("APPLIANCES CONDITION:"); lampstate=digitalRead(2); client.print("
LAMP:"); if(lampstate==HIGH) { client.println("ON "); } else { client.println("OFF "); } client.print("FAN :"); if (!strcmp(command, "5")) { analogWrite(FAN,244); client.println("ON
"); } else if(!strcmp(command, "6")) { analogWrite(FAN,57); client.println("ON "); } else if (!strcmp(command, "7")) { analogWrite(FAN,0); client.println("OFF ");
else if(fanstate==0)
client.println("OFF
"); } client.println("
if(c== '\n')
//we're starting a new line
current_line_is_first= false;
else if(c != '\r')
//we'e gotten a character on the current line
current_line_is_blank = false;
//get the first http request
if(current_line_is_first && c == '=')
for(int i=0;i<1;i++)
c=client.read();
command*=c;*
  • //LED control*
  • if(!strcmp(command,"3"))*
  • digitalWrite(LAMP,HIGH);*
  • else if(!strcmp(command,"4"))*
  • digitalWrite(LAMP,LOW);*
  • if(!strcmp(command,"1"))*
  • PIRstate=digitalRead(PIR);*
  • else if(!strcmp(command,"2"))*
  • PIRstate=0;*
  • //give the web browser time to receive the data*
  • delay(1);*
  • client.stop();*
(deleted)
Good example of why to use code tags.
Did you see it turned italic in the middle there? There's an array called command with elements called "i" and guess what?.... open square bracket followed by an i followed by a close square bracket is what turns italic on. So that few characters of your code has been interpreted rather than appearing on the screen.
spycatcher2k:
OK - So what is your question? If it's 'when ever i tried to compiled i got the error such as 'Ethernet' was not declared in this scope is it because i change the libraries from arduino ide w5100 to 5200' Then post a link to the library (correctly), your code (Correctly) and wha you have changed to modify the code to work with a totally different library . . . . please.
ok I'm so nervous n I don't event understand my own word! Haha I mean does different ethernet shield such as w5100 and w5200 version. Had different declaration such when I used w1500 on libraries it sadi inital was #include<ethernet.h> but for the w5200 it used #include<EthernetServerV2_0.h> does it play the importan role for the whole programming structure?
JimboZA:
Which mean? So overall my html is okay?
Mickey90:
No it means your code is impossible to read... Use the code tag # above the :sweat_smile: so that
it
looks like
this
#7 below
http://forum.arduino.cc/index.php/topic,148850.0.html
i got error in programming that on serial port when i give command it shows G
G
her is the code of my project please help me out of this problem
 Arduino with Ethernet Shield
#include <SPI.h>
#include <Servo.h>
int aled = 4;
int bled = 5;
int cled = 8;
int dled = 9;
const byte ledPin =  3;    // LED pin
const byte motionPin = 2;   // motion detector input pin
byte senseMotion = 0 ;
Servo microservo;
int pos = 0;
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };   //physical mac address
byte ip[] = { 169, 254, 109, 80 };                      // ip in lan (that's what you need to use in your browser. ("192.168.1.178")
byte gateway[] = { 169, 254, 109, 254 };                   // internet access via router
byte subnet[] = { 255, 255, 0, 0 };                  //subnet mask
EthernetServer server(80);                             //server port
String readString;
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  pinMode(ledPin, OUTPUT);
  pinMode(motionPin, INPUT);
  pinMode(aled, OUTPUT);
  pinMode(bled, OUTPUT);
  pinMode(cled, OUTPUT);
  pinMode(dled, OUTPUT);
  microservo.attach(7);
  // start the Ethernet connection and the server:
  Ethernet.begin(mac, ip, gateway, subnet);
  server.begin();
  Serial.print("server is at ");
  Serial.println(Ethernet.localIP());
  // Create a client connection
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        //read char by char HTTP request
        if (readString.length() < 100) {
          //store characters to string
          readString += c;
          //Serial.print(c);
         // Now watch for burglers
    senseMotion = digitalRead(motionPin);
    if (senseMotion == HIGH) {    // burgler found!
      digitalWrite(ledPin, HIGH);
    } else {                      // no burgler, yet...
      digitalWrite(ledPin, LOW);
         //if HTTP request has ended
         if (c == '\n') {
           Serial.println(readString); //print to serial monitor for debuging
           client.println("HTTP/1.1 200 OK"); //send new page
           client.println();
           client.println("<HTML>");
           client.println("<HEAD>");
            client.println("<body bgcolor=\"#22e3c3\">");
           client.println("<meta name='apple-mobile-web-app-capable' content='yes' />");
           client.println("<meta name='apple-mobile-web-app-status-bar-style' content='black-translucent' />");
           client.println("<link rel='stylesheet' type='text/css' href='http://randomnerdtutorials.com/ethernetcss.css' />");
           client.println("<TITLE>Random Nerd Tutorials Project</TITLE>");
           client.println("</HEAD>");
           client.println("<BODY>");
           client.println("<H1>Home Automation by Technology Department</H1>");
           client.println("<hr />");
           client.println("
           client.println("<H2>Arduino with Ethernet Shield</H2>");
           client.println("
           client.println("<a href=\"/?button1on\"\">Turn On 1LED</a>");
           client.println("<a href=\"/?button1off\"\">Turn Off 1LED</a>
           client.println("
           client.println("
           client.println("<a href=\"/?button2on\"\">Turn On 2LED</a>");
           client.println("<a href=\"/?button2off\"\">Turn Off 2LED</a>
           client.println("
           client.println("
           client.println("<a href=\"/?button3on\"\">Turn On 3LED</a>");
           client.println("<a href=\"/?button3off\"\">Turn Off 3LED</a>
           client.println("
           client.println("
           client.println("<a href=\"/?button4on\"\">Turn On 4LED</a>");
           client.println("<a href=\"/?button4off\"\">Turn Off 4LED</a>
           client.println("
           client.println("
           client.println("<a href=\"/?button5on\"\">Rotate Left Direction</a>");
           client.println("<a href=\"/?button5off\"\">Rotate Right Direction</a>
           client.println("
           client.println("
           client.println("
           client.println("<a href=\"/?button6off\"\">Turn off alarm</a>");
           client.println("
           client.println("
            client.println("<big>Engg Technologist;</big>");
            client.println("                 <small>JALAL KHAN;</small>");
            client.println("            <small>M.AQEEL;</small>");
            client.println("         <small>M.MEHBOOB ANJUM;</small>");
            client.println("      <small>EHSAN-E-ABDULLAH;</small>");
           client.println("
           client.println("</BODY>");
           client.println("</HTML>");
           delay(1);
           //stopping client
           client.stop();
           //controls the Arduino if you press the buttons
           if (readString.indexOf("?button1on") >0)
               digitalWrite(aled, HIGH);
           if (readString.indexOf("?button1off") >0)
               digitalWrite(aled, LOW);
            if (readString.indexOf("?button2on") >0)
               digitalWrite(bled, HIGH);
           if (readString.indexOf("?button2off") >0)
               digitalWrite(bled, LOW);
             if (readString.indexOf("?button3on") >0)
               digitalWrite(cled, HIGH);
           if (readString.indexOf("?button3off") >0)
               digitalWrite(cled, LOW);
            if (readString.indexOf("?button4on") >0)
               digitalWrite(dled, HIGH);
           if (readString.indexOf("?button4off") >0)
               digitalWrite(dled, LOW);
           if (readString.indexOf("?button5on") >0)
                for(pos = 0; pos < 180; pos += 3)  // goes from 0 degrees to 180 degrees
                {                                  // in steps of 1 degree
                  microservo.write(pos);              // tell servo to go to position in variable 'pos'
                  delay(15);                       // waits 15ms for the servo to reach the position
           if (readString.indexOf("?button5off") >0){
                for(pos = 180; pos>=1; pos-=3)     // goes from 180 degrees to 0 degrees
             if (readString.indexOf("?button6off") >0)
             digitalWrite(senseMotion, LOW);
            //clearing string for next read
             readString="";
