I want to control 10 pcs. of 10W RGB LEDs at 12V, including being able to change the color of each LED seperately, preferably at high speed.
I'm thinking that I can control them over I2C bus with several PCA9685, each giving me 16 PWM outputs.
But obviously I cannot draw the current from the chip, so what else can I do?
Essentially I want to amplify the 5V PWM output. Since each channel R,G,B might have different maximum voltages, I'm planning to provide a constant 12V, 11V and 8V VDC power source.
So, perhaps the 5V PWM output could serve as a signal to a high-speed transistor, thus resulting in respectively 12V, 11V or 8V in PWM form?
Is this a good design? Is there a better way?
