Home monitoring (NOT control) libraries?
I'm about to start a home monitoring project using several ESP8266s sending MQTT --> Mosquito --> InfluxDB --> Grafana.
I see a lot of libraries out there for home AUTOMATION but not any about home MONITORING. I see tons of monitoring projects too, but not reusable monitoring libraries. Mind you, this would be pretty easy code for me to write myself, but if someone has already done it, I would rather reuse it. Are there currently-active projects like this out there that I've missed?
Thanks.
dj_segfault:
Very likely, but nobodywill give you an answer until you are more forthcoming about what you want to do.
I would have thought that any home automation project would have the monitoring portion as a subset. Don't use the controller parts and hopefully the linker will drop it for you.
dj_segfault:
I see a lot of libraries out there for home AUTOMATION but showbox not any about home MONITORING. I see tons of monitoring projects too, but not reusable monitoring libraries. Mind you, this would be pretty easy code for me to write myself, but if someone has already done it, I would rather reuse it. Are there currently-active projects like this out there that I've missed?
Thanks.
The monitoring portion is a subset of home automation project.
com.google.monitoring-client metrics 1.0.5 This might be helpful to you. [new year motivational quotes](https://happynewyear2020quotesz.com/)
