just wanted to bounce a hypothetical off you guys.
say an industrial grade fog machine was connected to the central air system in a house.
then have an arduino connected to both the fogger and the web. a phone could run an application that connects to a webserver and essentially be able to send control packets to a framework that the arduino fog machine controller connects to.
if an alarm detects a break in from the house you'd get an alert on the phone which links to a webcam so you could see if theres actually someone there. then use the control application on the phone to engage the fog. which would basically just switch on the fogger and turn on the central air's main circulation fan and start pumping throughout the house.
this would start fogging out the house so the intruder couldnt see much. or the fogger could also be implemented in specific rooms only.
Anyone's input on this would be interesting.
