Homemade BIOS sketch problem.
Hi Arduino Forum!
I'm making a simple "homemade" computer.
I'm making a BIOS for my pc to simplify the operations.
Also i added 8 virtual registers for my BIOS sketch.
But i have a problem. My "move" void is not working.
My code:
typedef int Register;
void Mov(Register x, Register y);
Register VAX, VBX, VCX, VDX, VEX, VGX, VHX;
  x = y;
  Mov (VAX, 15);
 Serial.println(VAX);
But the serial output is always 0. My "mov" function doesn't change the VAX's value.
But if i write "VAX = 15;" instead of "Mov (VAX, 15);" there is no problem.
Is there a fix for it? I'm using Arduino Software 1.6.5 and Arduino Board Uno.
You need to pass your variables by reference, otherwise you just work with local copies.
void Mov(Register &x, Register y) { ** x = y;** }
The left hand side is a reference now.
pYro_65: You need to pass your variables by reference, otherwise you just work with local copies.
Wow thanks! It worked. Thank you very much.
