"homing" function does not work well
# include <AccelStepper.h>
const int dirPin= 3;
const int stepPin=2;
long steps = 0;       // The number of steps the motor runs per delay
long accelration = 0; // The current acceleration applied to the motor
long speed = 0 ;      // The current speed applied to the motor
long home_reference = 0 ; // a variable that used to remeber the home of the sensor
String commands; // the command from User
/* stop // means stop the motor
  start // means restart the motor
  set accelertion // give an acceleration to the motor
  reset // the motor will back to the initial place
bool Switch = true;
bool data_recevied, run_allowance = false;
AccelStepper myStepper(AccelStepper::DRIVER,dirPin,stepPin);
  Serial.println("The motor is now activated, please enter Commands");
  myStepper.setMaxSpeed(2000); // limit the value of setspeed (unit step/sec)
  //myStepper.setAcceleration(2000); // The defalut value of acceleration (unit step/sec^2)
  myStepper.disableOutputs(); // provide a low voltage to the driver when no Commands is provided
  myStepper.setCurrentPosition(0);
  Command_action();
  if(run_allowance)
    keep_running();
void Command_action()
  if (Serial.available()>0)
    commands = Serial.readString();
    commands.trim();
    data_recevied = true;
  if (data_recevied)
    if(commands == "start")
      run_allowance = true;
      Serial.println("please enter the value of steps (positive number only)");
      while(Serial.available() == 0){};
      steps = Serial.parseFloat()-1; // The motor will move one additional step to stop
      Serial.print("STEP : ");
      Serial.println(steps+1);
      myStepper.move(steps);
      Serial.end();
      Serial.println("please enter the value of speed");
      speed = Serial.parseFloat();
      Serial.print("SPEED :");
      Serial.println(speed);
      myStepper.setSpeed(speed);
      Serial.println(myStepper.speed());        // Testing only
      Serial.println(myStepper.targetPosition()); // Testing only
      Serial.println(myStepper.currentPosition()); // Testing only
      Serial.println("intial setting is done, the motor start to rotating ");
      delay(10000);
      Serial.end();
      data_recevied = false;
    else if(commands == "stop")
     home_reference = home_reference + myStepper.currentPosition();
     myStepper.setCurrentPosition(0);           // Remeber to call this function inside the homing function
     myStepper.stop();
     Serial.println("The Stepper is now stop and the position has been already reset");
     Serial.end();
    else if (commands == "homing" )
      Switch = false;
      myStepper.setSpeed(200);
      myStepper.move(-1*home_reference);
      //myStepper.setSpeed(200);
      Serial.println(" The motor is now homing");
      Serial.end();
      Serial.println("not available command");
void keep_running()
  if(run_allowance && abs(myStepper.targetPosition()) >= abs(myStepper.currentPosition()))
    myStepper.enableOutputs();
    myStepper.runSpeed();
    Serial.print("curr POS: ");
    if (Switch)
    }        // Update the home reference
    //myStepper.stop();
    Switch = true;
    Serial.println("Action done!");
I am not sure why, the homing function does not work well, can anyone help me to solve this problem ?
What does this mean ?
What should it do and what does it do ?
Maybe your homing sequence is effected by the use of delay and Serial
Try "homing" without the above statements... and while we are here, do you need Serial.end() with Serial.begin() immediately after... ever? The purpose of Serial.end() to "... disable serial communication, allowing the RX and TX pins to be used for general input and output..."
