HI everyone
I'm struggelig currently…
I use A4899 Drivers to control 5 Steppers (use Stepperdriver Libary)
I wanna set a Home position with physical endstops.
I'm currently using the following code, which somehow works, but i would like to set the home positions in the setup
Any advise?
Thanks a lot
Ansteuerung.ino (3.03 KB)
system
2
Move these functions into setup() after Serial.begin().
Homing_R();
Homing_Arm1();
Homing_Arm2();
Homing_Arm3();
Homing_GR();
This is not Google. You are allowed to write paragraphs.
You have the equipment in front of you. We don't. Please explain the problem in more detail.
MarkT
4
Homing needs to be in a while loop inside setup(). The while loop should terminate when all the
motors are at home position.
By A4899 I presume you actually mean A4988 ?
