Hope its easy to fix
just started and i get this message when i run my code
Sketch uses 2 774 bytes (8%) of program storage space. Maximum is 32 256 bytes.
Global variables use 105 bytes (5%) of dynamic memory, leaving 1 943 bytes for local variables. Maximum is 2 048 bytes.
anyone knows how to fix this?
dont think its anythin wrong with the code, but here it is.
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
const int switchPin = 6;
int switchState = 0;
int prevswitchState = 0;
int reply;
 lcd.begin(16, 2);
 pinMode(switchPin, INPUT);
 lcd.print("Ask the");
 lcd.setCursor(0, 1);
 lcd.print("crystalball");
 switchState = digitalRead(switchPin);
 if (switchState != prevswitchState) {
   if (switchState == LOW) {
     reply = random(8);
     lcd.clear();
     lcd.setCursor(0, 0);
     lcd.print ("The Ball Says");
     lcd.setCursor (0, 1);
     switch (reply) {
       case 0:
         lcd.print("yes");
       case 1:
         lcd.print("I DONT KNOW");
       case 2:
         lcd.print("no");
 prevswitchState = switchState;
hope u can help me
u :smiley:
Those are just details about your memory. Is the prototype not working? If so, double check the schematic. The code looks fine; it's right out of the Starter Kit labs.
hope u can help me
Sure, I added code tags for you, Next time do the same please, it's the </> button.
Use capitalization and spell out words. I am not a "u".
I'd be really worried if running that code produced that output.
