µHost - Minimalist Arduino board for budget design
Hi folks,
Just wanted to share my last design called µHost, a minimalist Arduino compatible board to host your Arduino projects when budget is very tight - and you don't need the fancy USB compatibility to run your design!
|500x375
Main characteristics: - Arduino UNO REV3 pinout, plus peripherals such as voltage regulators and pin 13 LED, for maximum compatibility with the existing Arduino shield ecosystem - mixed CMS and THT component footprint to be able to install the board with whatever component you have in your DIY electronics personal collection, - Standard 5x5cm frame compatible with generic low cost PCB pool services, - programming via ISP thanks to another Arduino board, or ISP programmer (No USB capability)
The concept beyond µHost is to have a minimalist Arduino compatible setup for DIY projects without the need of a full featured, USB enabled, generic Arduino board. Take that PCB, populate the components you need to run your minimalist Arduino setup, plug your shield on it, and you're good to go!
And yes, using it is really cheap: if ordering online via a low cost PCB pool service with parts aside, board pricing goes below 5€ per board when building a batch of 10 boards. That's really worth the deal when you are dealing with instancing multiple boards on an application without the need for USB capability!
Eagle CAD files are available here : https://github.com/bansonfr/uhost Detailed description and setup guidance : http://www.banson.fr/wiki/doku.php?id=uhost
It's been a useful tool to bench stuff and make standalone geeky toys at home. Hope you'll find it useful too!
D4
I don't know how useful the $hield header is for budget situations... shields all seem to be 2-10 times the price of functionally equivalent modules. If it actually fits in 5x5cm, it's way less than 5 euros/board to make in quantities of 10...
I like your flexible part outlines though, I've been thinking of doing something like that for the passives on my breakout boards to make life easier on people who fear SMD soldering. I don't like that crystal footprint, though - it doesn't look like it will accept a lot of common SMD crystal packages, which are still in common use (because they're the cheapest!). If you look at the boards I'm selling on tindie , you can see what I did for the crystal outline. It takes up alot of board space, but you can put just about any crystal package onto it.
ICSP header is not in standard location tho - so shields needing that are out of luck.
Many folks use a 3-terminal resonator to keep costs down.
The design doesn't provide an FTDI-type header to allow a USB/Serial module to easily connect for debugging via IDE Serial Monitor.
The constantly moving picture is also pretty annoying.
Thanks for the constructive feedback. Highly appreciated.
