Hot plug adafruit sd logger shield causes windows USB disconnect chime
I am a bit puzzled by this, although finding the answer is not critical to my project. When I have Arduino powered via usb and then plug the new adafruit sd logger shield to it, I hear the windows USB disconnected chime and pwr LED is off so I jerk the shield right off.
With the original version this is not happening:
Notice this is transient. If I connect the UNO to the shield and plug it into usb, it powers up normally. I tested the pins, just the power pins on bottom left corner makes the windows play USB disconnected chime :slight_smile: Any clue to this mystery?
Sounds like a power supply problem.
Maybe there's a big decoupling capacitor on there that sucks a huge amount of current when it's powering up, causing a voltage drop and resetting the USB.
fungus:
Possible but everything is surface mount. (ok, after looking, they are 10uF) The original version has two caps for 3.3 V regulator but won't cause the chime. (ok, after looking, they have 100uF!)
http://learn.adafruit.com/assets/9094
liudr:
fungus:
They only have to work at 5V so don't let the physical size fool you, some of those surface mount caps have quite big capacitance. SD cards need a fair bit of power (over 200mA) so I'd expect them to be hefty.
Another possibility is that some data pins connect before the power pins and cause a short.
Bottom line: Plugging shields in while the Arduino is powered up isn't a good idea.
It only requires the power row to contact the arduino to hear the chime so no data pins. I'm sure I'll not do hot plug anymore. Just can't figure out the difference between these two versions. Old version with larger caps are ok but new ones with small caps are drawing too much transient current :slight_smile:
