House AC best method?
I am just starting to collect parts to build a House power usage system.
I find that there three common methods to convert and read the 120 vac with regular analog input.
A. Step-down transformer (9vac) to voltage splitter and full sign wave placed at + 2.5 v offset. Advantage - able to read full wave.
B. Step-down transformer to full wave bridge, cap to average, voltage splitter and 5.1 v zener to protect.
advantage -- average RMS DC delivered.
C. Step-down transformer to one diode, voltage splitter. Measure + peak only. Advantage low part count. easy arithmetic to account for .2 v diode drop and 1/2 wave.
Are there other methods?
What are your thoughts?
John
Lots of ideas and implementations here: http://openenergymonitor.org/
This device used a custom interface. No thanks.
John
For some projects, yes. But you did not look very far. See this: Learn: Electricity Monitoring — OpenEnergyMonitor 0.0.1 documentation
Especially these:
http://openenergymonitor.org/emon/buildingblocks/ct-sensors-interface
http://openenergymonitor.org/emon/buildingblocks/measuring-voltage-with-an-acac-power-adapter
I don't see how measuring the voltage tells you anything about usage. So you have 120 V. so what ?
How does that tell you about usage ?
Where were you planning to connect your monitoring circuit ?
jremington:
Especially these:
Yes, you are correct,
good details that match my listed 'A' method. Good to know about the phase error rates.
I will have to search to see if like devices are available for 120v mains. At my location I will need two.
Imbalance in the split phase service is common problem here, Costa Rica.
John
raschemmel:
Yes, I will also have two current transformers at the service entry point on the split phase service. That is an additional issue large enough to have a unique thread.
The bottom line of my question: Is the peek level of just the + side of the AC sufficient for this application or do I need to measure the full sign wave? I can compute the RMS from either but are there errors introduced when I move to a power computation with the current measurements?
the wonderful thing about arduinos is that you can try all three!
Let Arduino Yun Measure/Datalog DCV/ACV/DCA/ACA/R/CAP/Freq/Temperature
http://forum.arduino.cc/index.php?topic=278719.0
by select multi-purpose meter which support RMS, we could get better result.
