It is same as of UART. So i hooked it to the serial pin of the ardunio and tried to decode it by changing baud rates, but it did not work, nothing got print to it.
So i decided to decode it manually. By browsing i found that the pulse with duration
32+88 is a 1 and pulse with duration 32+48 is a 0 and the long pulse the gap between the data stream.
I decoded it the format of binary as 1 and 0.
But I found that every 3 minutes it changes the
Pattern.
So my question is can a ardunio do it for me??
If yes!!
how should i program??
Do you understand PWM (Pulse Width Modulation)? If you do not understand PWM then you will be lost with VPWM. As far as links there are are probably hundreds if not thousands that will explain it. Start here and exercise your search engine.
The model a I am not sure.
But the company of the aircon is samsung and it has two unit to operate a indoor unit and a outdoor unit. As per the information i got the indoor unit sends the pulse to the out door unit to run the compresser
Take a search engine of your choice and ask the WWW for 'aircon samsung +communication interface' to collect some data to be sorted out to get the needed information.
