How accurate is this? Thermometer with arduino uno
So I built this a couple of years ago, believe it or not, and haven’t really used it. Well, it’s getting hot again and my room is getting groggy. So I want to see what my temperature in my room is using this, since I already got it :stuck_out_tongue:
I’m using a RGB-LED, and assigning the values of red/green/blue based on the temperature. I didn’t make the “formula” for the color that accurate, it was mostly based on try/fail.
However, I’m not worried about what color it shows in color as much as I am it showing the correct temperature.
Here’s the code I’ve got currently.
const int TEMP_PIN = 6;
const int RED_LED_PIN = 9;
const int GREEN_LED_PIN = 10;
const int BLUE_LED_PIN = 11;
int redIntensity = 0;
int greenIntensity = 0;
int blueIntensity = 0;
 float temperature = getVoltage(TEMP_PIN);
 temperature = ((temperature - .5) * 100)*1.2;
 Serial.println(temperature);
 if(temperature >= 10.00 && temperature <= 255){
   blueIntensity = temperature + 120;
   analogWrite(BLUE_LED_PIN, blueIntensity);
 if(temperature >= 70.00 && temperature <= 255){
   blueIntensity -= 40;
   greenIntensity = temperature + 100;
   analogWrite(GREEN_LED_PIN, greenIntensity);
 if(temperature >= 80.00 && temperature <= 255){
   blueIntensity = 0;
   greenIntensity = 0;
   redIntensity = temperature + 90;
   analogWrite(RED_LED_PIN, redIntensity);
float getVoltage(int pin){
 return (analogRead(pin) * .004882814);
Here’s what the current output is in my room (It feels hotter than 75 degrees, hence why I’m asking if my data is accurate):
116.99
96.97
86.23
80.86
78.42
76.95
76.46
75.98
75.98
75.98
75.98
75.98
75.98
75.98
75.98
75.49
75.49
75.49
It starts high and then it eventually drops down to what it’s reading. So it didn’t suddenly drop 40 degrees.
Thanks all for your time.
try putting a thermometer next to the sensor and checking
BulldogLowell: try putting a thermometer next to the sensor and checking
I actually don't have one :astonished:
SimpleMindedMan:
0 and 100 are easy enough to check, even if you live at high altitude. If you can't come at that, try investing $3 in a sensor that you can have more faith in, like a DS18B20.
As it happens, a simple thermistor can be pretty good over a narrow range like room temperatures. If that is what you are using, I would be more inclined to trust it than your feelings. The strange initial readings are probably some aberration, easily fixed or easily ignored.
We need a datasheet for your sensor.
Sorry for the late reply, got busy.
Nick_Pyner:
SimpleMindedMan: 0 and 100 are easy enough to check, even if you live at high altitude. If you can't come at that, try investing $3 in a sensor that you can have more faith in, like a DS18B20.
I'm using a TMP36. It came in a kit I bought some time ago. I haven't been to an electronics store (like, one that carries parts and not tvs etc) in a while. I need to rewire my current project because looking at it again, it looks like mass chaos.
Jiggy-Ninja: We need a datasheet for your sensor.
http://www.analog.com/static/imported-files/data_sheets/TMP35_36_37.pdf
SimpleMindedMan: I'm using a TMP36. It came in a kit I bought some time ago.
OK, the same applies and you can still check it if you need to. Maybe the code is a little bit rough, but the TMP36 itself is popular and reputable.
Nick_Pyner:
Yeah the code is actually what I was wondering about. I wanted to know if it's accurate (just not the color showing part, I'll work the kinks out on that on my own :) )
I'm a DS18B20 user, so I can't comment. If it is reading something close to what you expect it is probably OK. When I said rough I just meant some minor procedural issue giving false readings at the start.
so as long as the temperature is between these values you keep on subtracting 40 from blueIntensity.
Think that should read
blueIntensity = Temperature - 40;
robtillaart:
Yeah I wrote this when I was new to programming. It honestly was one of my first projects. That’s actually why I’m trying to figure out the accuracy of the temperature.
I haven’t gotten the time to rewrite the color codes. I’m going to rework all the colors because reading it now, it looks bad. I want to dictate each color in it’s own method and give a more reasonable scale, because I don’t see me going anywhere near 255 degrees in temperature. I believe I did that just because the values the light can be are 0-255.
Thanks for the heads up though ^.^
