How and what do i need to control 2 x servos?
Hi
I am new to Arduino have just found out it may do what i need it to do.
I need Arduino to control two servos independently ie with the remote up/down for one of the servo and left/right for other servo.
Speed would need to be controled as the servos would need to turn slow.
What componets do i need and how do i do it?
Thanks for your time and help
A quick google search returns a ton of information.
These may help:
http://playground.arduino.cc/ComponentLib/Servo
Start with one servo, and once you understand how that works, then move to add the other one.
Have a look at the examples that come with the Arduino IDE - especially the servo-sweep example.
What are you thinking of using to provide the control inputs? - for example push-button switches or potentiometers, or a joystick that contains potentiometers.
Read as many Forum Threads as you can - they are a great source of knowledge, including "what not to do".
Have a look at planning and implementing a program.
This Thread about controls for an excavator may be of interest.
...R
I need Arduino to control two servos independently ie with the remote up/down for one of the servo and left/right for other servo. Speed would need to be controled as the servos would need to turn slow.
Below is a discussion on controlling the movement speed of a servo. Bottom is code for sending independent position commands to servos.
http://forum.arduino.cc/index.php/topic,61586.30.html
//zoomkat 11-22-12 simple delimited ',' string parse
//from serial port input (via serial monitor)
//and print result out serial port
//multi servos added
// Powering a servo from the arduino usually *DOES NOT WORK*.
String readString;
#include <Servo.h>
Servo myservoa, myservob, myservoc, myservod;  // create servo object to control a servo
  //myservoa.writeMicroseconds(1500); //set initial servo position if desired
  myservoa.attach(6);  //the pin for the servoa control
  myservob.attach(7);  //the pin for the servob control
  myservoc.attach(8);  //the pin for the servoc control
  myservod.attach(9);  //the pin for the servod control
  Serial.println("multi-servo-delimit-test-dual-input-11-22-12"); // so I can keep track of what is loaded
  //expect single strings like 700a, or 1500c, or 2000d,
  //or like 30c, or 90a, or 180d,
  //or combined like 30c,180b,70a,120d,
  if (Serial.available())  {
    char c = Serial.read();  //gets one byte from serial buffer
    if (c == ',') {
      if (readString.length() >1) {
        Serial.println(readString); //prints string to serial port out
        int n = readString.toInt();  //convert readString into a number
        // auto select appropriate value, copied from someone elses code.
        if(n >= 500)
          Serial.print("writing Microseconds: ");
          Serial.println(n);
          if(readString.indexOf('a') >0) myservoa.writeMicroseconds(n);
          if(readString.indexOf('b') >0) myservob.writeMicroseconds(n);
          if(readString.indexOf('c') >0) myservoc.writeMicroseconds(n);
          if(readString.indexOf('d') >0) myservod.writeMicroseconds(n);
          Serial.print("writing Angle: ");
          Serial.println(n);
          if(readString.indexOf('a') >0) myservoa.write(n);
          if(readString.indexOf('b') >0) myservob.write(n);
          if(readString.indexOf('c') >0) myservoc.write(n);
          if(readString.indexOf('d') >0) myservod.write(n);
         readString=""; //clears variable for new input
    else {
      readString += c; //makes the string readString
I would like control it via a 21 inch touch screen monitor connected to my pc. Would i need additional hardware to use a touch screen ?
Im buying one of theses are they good?
Arduino-Compatible R3 UNO ATmega16U2 AVR USB Board http://m.banggood.com/index.php?com=detail&t=index&products_id=68537
Did you read the reviews?
Yes i did see the reviews and it had loads of good reviews.
I bought one of the below and it worked as expected. $4.08 including shipping is a deal.
http://www.ebay.com/itm/261653306720?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
