How Arduino actually gets measurements
I was given a project on a small power system. Basically an Arduino Uno (programmed in C) obtains measurements and outputs them onto a small LCD touchscreen display. The display can also set a couple of parameters (which i am not concerned about).
I am only concerned about the measurements the arduino is obtaining from this FPGA device. I was given this lengthy code, but I need help on understanding how the Arduino actually gets the measurements from the FPGA device. The section which I think is important is the //START Gather data from FPGA & display in Engineering Terms.
I have attached the code, and any help to understand this would be greatly appreciated.
Thanks.
UWA_UI_mega14i.ino (32.7 KB)
It looks like a simple raw data serial protocol over RS485. There should be a specification of the protocol? That would be very bad engineering if not.
Anyway the data is a sequence of 24 integers (16-bit) sent with LSB first. The last integer is a CRC. The format could be written in C++ as:
struct msg_t {
  int16_t header;
  int16_t V[8];
  int16_t I[8];
  int16_t T[4];
  int16_t Vfeedback[2];
  int16_t CRC;
There are a lot of obvious errors in the code that can give problems (such as the size of data[19] which should be data[24]).
Cheers!
Thanks for that!
I was wondering if you could summarize the how its actually checking for Serial data, Reading it, then storing it and printing it to the screen, perhaps in a flow diagram of sorts?
    for (k = 0; k < 2; k++)
      if (Serial1.available())
        int inByte = Serial1.read();
        Serial.print(inByte, DEC);
        Serial.print("  ");
    Serial.print("V  ");
    for (k = 0; k < 8; k++)
      for (j = 0; j < 2; j++)
        bufout[j] = Serial1.read();
      data[k] = bufout[0];
      data[k] += (bufout[1] << 8);
      Serial.print(data[k], DEC);
      Serial.print("\t");
      //    Serial.print(data[k]/327.68, 2); Serial.print("\t");
    S
That second set of Serial1.read looks suspect; reading from serial without first checking there’s data there to read - it looks like it’s relying on the delay introduced by the prints to “ensure” it works.
Edit: In fact, printing to a serial port that hasn’t been initialised is a really Bad IdeaTM
Do you want me to move this to “Gigs and collaborations” ?
Sure!
Hi, What is the device that the UNO gets its data from. If it is a commercial device we maybe able to help and make sure the input process is correct.
Thanks... Tom... :)
Uno?
Does the arduino and display work? Its hard to tell your first post. What is the problem?
Tom... :)
Ok, sorry not an Uno, it's actually a Mega.
The code does work, not particularly well. It was given to me.
I guess what i'm looking for is a breakdown of what's going on in the code, and ways I can improve it, so I can apply it to a different interface.
Sorry for not being clear in the original post.
TomGeorge: Hi, What is the device that the UNO gets its data from. If it is a commercial device we maybe able to help and make sure the input process is correct.
It get's its data from an FPGA connected to a small power system
You might want to start clearing up the problems I pointed-out in reply #3.
