Hello Guys, This is my first thread post on this forum.
I'm a beginner on Arduino's programming. I want to ask a question :
How arduino know the pin of each potensio without describing the ADC pin number.
I have a code below (credit to electrosmash):
Thanks Guys
Cheers ![]()
// Licensed under a Creative Commons Attribution 3.0 Unported License.
// Based on RCArduino.Blogspot.com previous work.
// www.electrosmash.com/pedalshield
// tremolo effect produces a variation in the volume of the signal, by mixing the guitar with a sinusoidal waveform.
// potentiometer 0: controls the speed.
// potentiometer 1: controls the deph.
// potentiometer 2: controls the volume level.
int in_ADC0, in_ADC1;Â //variables for 2 ADCs values (ADC0, ADC1)
int POT0, POT1, POT2, out_DAC0, out_DAC1; //variables for 3 pots (ADC8, ADC9, ADC10)
const int LED = 3;
const int FOOTSWITCH = 7;
const int TOGGLE = 2;
int sample, accumulator, count, LFO;
// Create a table to hold pre computed sinewave, the table has a resolution of 600 samples
#define no_samples 44100
#define MAX_COUNTÂ Â 160
uint16_t nSineTable[no_samples];//storing 12 bit samples in 16 bit variable.
// create the individual samples for our sinewave table
void createSineTable()
 for(uint32_t nIndex=0; nIndex<no_samples; nIndex++)
  // normalised to 12 bit range 0-4095
  nSineTable[nIndex] = (uint16_t) (((1+sin(((2.0*PI)/no_samples)*nIndex))*4095.0)/2);
 createSineTable();
 /* turn on the timer clock in the power management controller */
 pmc_set_writeprotect(false);
 pmc_enable_periph_clk(ID_TC4);
 /* we want wavesel 01 with RC */
 TC_Configure(TC1,1, TC_CMR_WAVE | TC_CMR_WAVSEL_UP_RC | TC_CMR_TCCLKS_TIMER_CLOCK2);
 TC_SetRC(TC1, 1, 238); // sets <> 44.1 Khz interrupt rate
 TC_Start(TC1, 1);
 // enable timer interrupts on the timer
 TC1->TC_CHANNEL[1].TC_IER=TC_IER_CPCS;
 TC1->TC_CHANNEL[1].TC_IDR=~TC_IER_CPCS;
 /* Enable the interrupt in the nested vector interrupt controller */
 /* TC4_IRQn where 4 is the timer number * timer channels (3) + the channel number
 (=(1*3)+1) for timer1 channel1 */
 NVIC_EnableIRQ(TC4_IRQn);
 //ADC Configuration
 ADC->ADC_MR |= 0x80; // DAC in free running mode.
 ADC->ADC_CR=2;    // Starts ADC conversion.
 ADC->ADC_CHER=0x1CC0; // Enable ADC channels 0,1,8,9 and 10Â
 //DAC Configuration
 analogWrite(DAC0,0); // Enables DAC0
 analogWrite(DAC1,0); // Enables DAC0
 //Read the ADCs
 while((ADC->ADC_ISR & 0x1CC0)!=0x1CC0);// wait for ADC 0, 1, 8, 9, 10 conversion complete.
 in_ADC0=ADC->ADC_CDR[7];       // read data from ADC0
 in_ADC1=ADC->ADC_CDR[6];       // read data from ADC1Â
 POT0=ADC->ADC_CDR[10];        // read data from ADC8   Â
 POT1=ADC->ADC_CDR[11];        // read data from ADC9Â
 POT2=ADC->ADC_CDR[12];        // read data from ADC10Â
void TC4_Handler()
 // Get the status to clear the interrupt to be fired again.
 TC_GetStatus(TC1, 1);
//Increase the sinewave index and/or reset the value.
POT0 = POT0>>1; //divide value by 2 (its too big)
count++;
if (count>=160) //160 chosen empirically
 count=0;
 sample=sample+POT0;
 if(sample>=no_samples) sample=0;
 //Create the Low Frequency Oscillator signal with depth control based in POT1.
 LFO=map(nSineTable[sample],0,4095,(4095-POT1),4095);
 //Modulate the output signals based on the sinetable.
 out_DAC0 =map(in_ADC0,1,4095,1, LFO);
 out_DAC1 =map(in_ADC1,1,4095,1, LFO);
 //Add volume feature with POT2
 out_DAC0 =map(out_DAC0,1,4095,1, POT2);
 out_DAC1 =map(out_DAC1,1,4095,1, POT2);
 //Write the DACs
 dacc_set_channel_selection(DACC_INTERFACE, 0);   //select DAC channel 0
 dacc_write_conversion_data(DACC_INTERFACE, out_DAC0);//write on DAC
 dacc_set_channel_selection(DACC_INTERFACE, 1);   //select DAC channel 1
 dacc_write_conversion_data(DACC_INTERFACE, out_DAC1);//write on DAC
