Can the Arduino be programmed to make the servos move at variable speeds?
Yes ,you can. You need to define a delay time. When you change this delay, Servo moves at different speeds. When you increase the delay time, that means, Servo moves more slowly.
for ( int j = servo[i]; j >= servo[i + 1]; j--) {
servo01.write(j);
delay(speedDelay);
like this. when you can change speed delay, and then servo moves at variable speeds.
Your post was MOVED to its current location as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
There is a library called VarSpeedServo to help with that.
Thank you for your reply! I think what you said works and I will try this!
Thanks for the reply, I'll learn how to use this library first!
