How can Arduino+Wifi Shield 2.0 (seeedstudio) receive data from database +xampp
I'm trying to connect my Arduino Mega 2560 via wi-fi to my xampp server.
My main objective is get a value at my database and store it on a variable in Arduino code. With this new variable I'll be able to control the rest of the program... so for that matter I need your help. Can someone give-me advice?
I already try every thing that i found in the internet but it just dosen't work.
I think that the simple way is to send a GET request to the server and read his response... but for some reason i cant send the GET request trought...
I test it on the browser directly and the value show up, so i think that the server side is allright.
Here is my Arduino Code:
#include <Arduino.h>
    #include <SoftwareSerial.h>
    #include "WiFly.h"
    #include "HTTPClient.h"
    #define SSID      "mySSID"
    #define KEY       "myKEY"
    #define AUTH      WIFLY_AUTH_WPA2_PSK
    #define HTTP_GET_URL "http://192.168.1.80/xampp/training/send_data_db.php/?$temp=0"
    // Pins' connection
    // Arduino       WiFly
    //  2    <---->    TX
    //  3    <---->    RX
    SoftwareSerial uart(10, 11);
    WiFly wifly(uart);
    HTTPClient http;
    char get;
      Serial.println("------- WIFLY HTTP --------");
      uart.begin(9600);         // WiFly UART Baud Rate: 9600
      // Wait WiFly to init
    //  delay(3000);
      // check if WiFly is associated with AP(SSID)
      if (!wifly.isAssociated(SSID)) {
        while (!wifly.join(SSID, KEY, AUTH)) {
          Serial.println("Failed to join " SSID);
          Serial.println("Wait 0.1 second and try again...");
          delay(100);
        wifly.save();    // save configuration,
    Serial.println("\r\nTry to get url - " HTTP_GET_URL);
      Serial.println("------------------------------");
      while (http.get(HTTP_GET_URL, 10000) < 0) {
      while (wifly.receive((uint8_t *)&get, 1, 1000) == 1) {
        Serial.print(get);
      if (wifly.commandMode()) {
        Serial.println("\r\n\r\nEnter command mode. Send \"exit\"(with \\r) to exit command mode");
      int c;
      while (wifly.available()) {
        c = wifly.read();
        if (c > 0) {
          Serial.write((char)c);
      while (Serial.available()) {
        c = Serial.read();
        if (c >= 0) {
          wifly.write((char)c);
And here is my PHP code:
<?php
    include("./connection/database_connect.php");
    include("./top_table.php");
    if((isset($_SESSION["ID"])) AND (isset($_GET["temp"])))
     $id=$_SESSION["ID"];
     $sql="SELECT temp FROM perfil, client WHERE perfil.ID ='$id'";
     $consult=mysqli_query($connect,$sql);
     $result=mysqli_num_rows($consult);
     if(($result==1))
     $person_data=mysqli_fetch_array($consult, MYSQLI_ASSOC);
     $temp=$person_data["temp"];
     header("HTTP/1.1" . " " . 200 . "OK");
     header("Content-Type: text/html; charset=UTF-8");
     header("Content-Length: 1112");
     header("Connection: close");
     header("/r/n");
     echo $temp;
     //se user dosen't exist on data base
     header("Location: http://192.168.1.80/xampp/training/login.php");
     exit;
     exit;
