How can I adapt this code for the ATTiny85?
So I set up an Arduino circuit that while a button was pressed, a sound effect would play and an LED would activate until I stopped pressing the button. Since I didn’t use a micro sd card module, I had to use wav2c to convert the audio to numeric values that I then used the code here to implement the audio. The numeric values for the audio were placed in a header file that was referenced in the code. The code and my circuit work but I want to see if I can use one of my new ATTiny85’s to run the code and perform the same operations as the Arduino did. I have set up my Arduino Mega 2560 to program the ATTiny85. I have tested it with Blink and it works. However, after I had moved the pins of the speaker, LED, and button to those of the ATTin85 and edited the appropriate code, it will not upload to the ATTiny85. It gives error messages that certain variables have not been declared in this scope. One such is “TCCR1B” and when I comment it out, it claims another variable has not been declared in this scope. Any idea how I can overcome this and if it’s even possible to use the ATTiny in this capacity?
The Code I tried uploading to the ATTiny85
#include <stdint.h>
#include <avr/interrupt.h>
#include <avr/io.h>
#include <avr/pgmspace.h>
#define SAMPLE_RATE 20000
#include "Test.h"
int ledPin = 0;
int speakerPin = 1; // Can be either 3 or 11, two PWM outputs connected to Timer 2
const byte pinSwitch1 = 2;
volatile uint16_t sample;
byte lastSample;
int buttonState = 0;
const byte interruptPin = 2;
volatile byte state = LOW;
void stopPlayback()
    digitalWrite(ledPin, LOW);
    // Disable playback per-sample interrupt.
    TIMSK1 &= ~_BV(OCIE1A);
    // Disable the per-sample timer completely.
    TCCR1B &= ~_BV(CS10);
    // Disable the PWM timer.
    TCCR2B &= ~_BV(CS10);
    digitalWrite(speakerPin, LOW);
// This is called at 8000 Hz to load the next sample.
ISR(TIMER1_COMPA_vect) {
    if (sample >= sounddata_length) {
        if (sample == sounddata_length + lastSample) {
            stopPlayback();
        else {
            if(speakerPin==11){
                // Ramp down to zero to reduce the click at the end of playback.
                OCR2A = sounddata_length + lastSample - sample;
                OCR2B = sounddata_length + lastSample - sample;
    else {
        if(speakerPin==11){
            OCR2A = pgm_read_byte(&sounddata_data[sample]);
            OCR2B = pgm_read_byte(&sounddata_data[sample]);
    ++sample;
void startPlayback()
    digitalWrite(ledPin, HIGH);
    pinMode(speakerPin, OUTPUT);
    // Set up Timer 2 to do pulse width modulation on the speaker
    // pin.
    // Use internal clock (datasheet p.160)
    ASSR &= ~(_BV(EXCLK) | _BV(AS2));
    // Set fast PWM mode  (p.157)
    TCCR2A |= _BV(WGM21) | _BV(WGM20);
    TCCR2B &= ~_BV(WGM22);
    if(speakerPin==11){
        // Do non-inverting PWM on pin OC2A (p.155)
        // On the Arduino this is pin 11.
        TCCR2A = (TCCR2A | _BV(COM2A1)) & ~_BV(COM2A0);
        TCCR2A &= ~(_BV(COM2B1) | _BV(COM2B0));
        // No prescaler (p.158)
        TCCR2B = (TCCR2B & ~(_BV(CS12) | _BV(CS11))) | _BV(CS10);
        // Set initial pulse width to the first sample.
        OCR2A = pgm_read_byte(&sounddata_data[0]);
        // Do non-inverting PWM on pin OC2B (p.155)
        // On the Arduino this is pin 3.
        TCCR2A = (TCCR2A | _BV(COM2B1)) & ~_BV(COM2B0);
        TCCR2A &= ~(_BV(COM2A1) | _BV(COM2A0));
        OCR2B = pgm_read_byte(&sounddata_data[0]);
    // Set up Timer 1 to send a sample every interrupt.
    cli();
    // Set CTC mode (Clear Timer on Compare Match) (p.133)
    // Have to set OCR1A *after*, otherwise it gets reset to 0!
    TCCR1B = (TCCR1B & ~_BV(WGM13)) | _BV(WGM12);
    TCCR1A = TCCR1A & ~(_BV(WGM11) | _BV(WGM10));
    // No prescaler (p.134)
    TCCR1B = (TCCR1B & ~(_BV(CS12) | _BV(CS11))) | _BV(CS10);
    // Set the compare register (OCR1A).
    // OCR1A is a 16-bit register, so we have to do this with
    // interrupts disabled to be safe.
    OCR1A = F_CPU / SAMPLE_RATE;    // 16e6 / 8000 = 2000
    // Enable interrupt when TCNT1 == OCR1A (p.136)
    TIMSK1 |= _BV(OCIE1A);
    lastSample = pgm_read_byte(&sounddata_data[sounddata_length-1]);
    sample = 0;
    sei();
        //digitalWrite(ledPin, HIGH);
        //delay(1000);
        //digitalWrite(ledPin, LOW);
    pinMode( pinSwitch1, INPUT );
    pinMode(ledPin, OUTPUT);
    pinMode(interruptPin, INPUT_PULLUP);
    attachInterrupt(digitalPinToInterrupt(interruptPin), stopPlayback, CHANGE);
//startPlayback();
//delay(5000);
//stopPlayback();
buttonState = digitalRead(pinSwitch1);
stopPlayback();
if (buttonState == LOW) {
    startPlayback();
    delay(1150);
The header file with the audio
#ifndef _HEADERFILE_H    // Put these two lines at the top of your file.
#define _HEADERFILE_H    // (Use a suitable name, usually based on the file name.)
const int sounddata_length=32000;
//const int sounddata_sampleRate=20000;
const unsigned char sounddata_data[] PROGMEM = {
  15,1,49,0,150,0,138,0,219,255,133,0,176,0,15,1,210,
//There are a lot more numbers in here to generate the audio but I cut most out to save space
#endif // _HEADERFILE_H    // Put this line at the end of your file.
An ATTiny85 only has two timers, Timer0 and Timer1. There is no Timer2 so you will need to adjust your code.
Also, since there are not as many timers, there is no TIMSK1 but rather just TIMSK. Same for TCCR1B which is just TCCR1.
Since this code does direct register manipulation, you will have to study the ATtin785 datasheet and figure out that mapping... datasheet
