I have made a simple project that reads två sensors and via Wifi connects to Xively to upload the sensors values. However for some reason the loop stops and a forced reset is needed to get the loop started again. (not optimal)
my skills are bit limited but my idea would be to add an interup reset based on timer? e.g. if loop is not completed in 30sec then reset loop. However i would need help to understand where in my code i should put the interupt and possible also example code.
any good ideas is apriciated.
// Libraries
#include <Adafruit_CC3000.h>
#include <ccspi.h>
#include <SPI.h>
#include <string.h>
#include "utility/debug.h"
#include "DHT.h"
#include<stdlib.h>
// Define CC3000 chip pins
#define ADAFRUIT_CC3000_IRQ 3
#define ADAFRUIT_CC3000_VBAT 5
#define ADAFRUIT_CC3000_CS 10
// DHT sensor
#define DHTPIN 53
#define DHTTYPE DHT22
// Create CC3000 instances
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS, ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT,
SPI_CLOCK_DIV2); // you can change this clock speed
// DHT instance
DHT dht(DHTPIN, DHTTYPE);
// WLAN parameters
#define WLAN_SSID "xxxxx"
#define WLAN_PASS "xxxxx*"
// Security can be WLAN_SEC_UNSEC, WLAN_SEC_WEP, WLAN_SEC_WPA or WLAN_SEC_WPA2
#define WLAN_SECURITY WLAN_SEC_WPA2
// Xively parameters
#define WEBSITE "api.xively.com"
#define API_key "zzzzzzzz"
#define feedID "zzzzzzzzz"
uint32_t ip;
void setup(void)
// Initialize
Serial.println(F("\nInitializing..."));
if (!cc3000.begin())
Serial.println(F("Couldn't begin()! Check your wiring?"));
while(1);
void loop(void)
// Connect to WiFi network
cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY);
Serial.println(F("Connected!"));
/* Wait for DHCP to complete */
Serial.println(F("Request DHCP"));
while (!cc3000.checkDHCP())
delay(100);
// Get the website IP & print it
ip = 0;
Serial.print(WEBSITE); Serial.print(F(" -> "));
while (ip == 0) {
if (! cc3000.getHostByName(WEBSITE, &ip)) {
Serial.println(F("Couldn't resolve!"));
cc3000.printIPdotsRev(ip);
// Get data & transform to integers
float h = dht.readHumidity();
float t = dht.readTemperature();
int temperature = (int) t;
int humidity = (int) h;
// Prepare JSON for Xively & get length
int length = 0;
String data = "";
data = data + "\n" + "{\"version\":\"1.0.0\",\"datastreams\" : [ {\"id\" : \"Temperature\",\"current_value\" : \"" + String(temperature) + "\"},"
+ "{\"id\" : \"Humidity\",\"current_value\" : \"" + String(humidity) + "\"}]}";
length = data.length();
Serial.print("Data length");
Serial.println(length);
// Print request for debug purposes
Serial.print("PUT /v2/feeds/");
Serial.print(feedID);
Serial.println(".json HTTP/1.0");
Serial.println("Host: api.xively.com");
Serial.print("X-ApiKey: ");
Serial.println(API_key);
Serial.print("Content-Length: ");
Serial.println(length, DEC);
Serial.print("Connection: close");
Serial.print(data);
// Send request
Adafruit_CC3000_Client client = cc3000.connectTCP(ip, 80);
if (client.connected()) {
Serial.println("Connected!");
client.println("PUT /v2/feeds/" + String(feedID) + ".json HTTP/1.0");
client.println("Host: api.xively.com");
client.println("X-ApiKey: " + String(API_key));
client.println("Content-Length: " + String(length));
client.print("Connection: close");
client.println();
client.print(data);
client.println();
Serial.println(F("Connection failed"));
return;
Serial.println(F("-------------------------------------"));
while (client.connected()) {
while (client.available()) {
char c = client.read();
Serial.print(c);
client.close();
Serial.println(F("\n\nDisconnecting"));
cc3000.disconnect();
// Wait 10 seconds until next update
delay(10000);
Serial output as it should look when loop is succesfull
Started AP/SSID scan
Connecting to slow...Waiting to connect...Connected!
Request DHCP
api.xively.com -> 216.52.233.120Data length128
PUT /v2/feeds/zzzzzzzzz.json HTTP/1.0
X-ApiKey: zzzzzzzzzz
Content-Length: 128
Connection: close
{"version":"1.0.0","datastreams" : [ {"id" : "Temperature","current_value" : "23"},{"id" : "Humidity","current_value" : "24"}]}
Connect to 216.52.233.120:80
Connected!
HTTP/1.1 200 OK
Date: Sat, 29 Mar 2014 07:08:49 GMT
Content-Type: application/json; charset=utf-8
Content-Length: 0
Connection: close
X-Request-Id: 80d4b2d4d0ec76967005b023247276b33e9ef5eb
Cache-Control: max-age=0
Vary: Accept-Encoding
Disconnecting
Serial output when failed
Request DHCP
PUT /v2/feeds/zzzzzzzz.json HTTP/1.0
X-ApiKey: zzzzzzzzzzzz
Content-Length: 128
Connection: close
Connected!
