How can I add bluetooth in this code --please help
hey all
I have made a 48x8 led display to display scrolling text in it.
but I want to change the text through my android phone using bluetooth and I will be using HC-05 bluetooth module for that purpose.
my question is
1–>what code should I include to the given code to change the text from mobile?
2–> How can I add more characters?
I am new to arduino …sorry if i have done any mistake here and also for my bad English.
here is the full code…
// Arduino code to display scrolling characters on 6 or more 8x8 LED matrix.    *
char msg[] ="WEL COME  ";//Change the text here.
int scrollspeed=4;//Set the scroll speed ( lower=faster)
int x;
int y;
//Columns
int clockPin1 = 2; //Arduino pin connected to Clock Pin 11 of 74HC595
int latchPin1 = 3; //Arduino pin connected to Latch Pin 12 of 74HC595
int dataPin1 = 4;  //Arduino pin connected to Data Pin 14 of 74HC595
//Rows
int clockPin2 = 5; //Arduino pin connected to Clock Pin 11 of 74HC595
int latchPin2 = 6; //Arduino pin connected to Latch Pin 12 of 74HC595
int dataPin2 = 7;  //Arduino pin connected to Data Pin 14 of 74HC595
//BITMAP
//Bits in this array represents one LED of the matrix
// 8 is # of rows, 6 is # of LED matrices
byte bitmap[8][7];
int numZones = sizeof(bitmap) / 8; // One Zone refers to one 8 x 8 Matrix ( Group of 8 columns)
int maxZoneIndex = numZones-1;
int numCols = numZones * 8;
//FONT DEFENITION
byte alphabets[][8] = {
 {0,0,0,0,0},//@ as SPACE
 //{8,28,54,99,65},//<<
 {31, 36, 68, 36, 31},//A
 {127, 73, 73, 73, 54},//B
 {62, 65, 65, 65, 34},//C
 {127, 65, 65, 34, 28},//D
 {127, 73, 73, 65, 65},//E
 {127, 72, 72, 72, 64},//F
 {62, 65, 65, 69, 38},//G
 {127, 8, 8, 8, 127},//H
 {0, 65, 127, 65, 0},//I
 {2, 1, 1, 1, 126},//J
 {127, 8, 20, 34, 65},//K
 {127, 1, 1, 1, 1},//L
 {127, 32, 16, 32, 127},//M
 {127, 32, 16, 8, 127},//N
 {62, 65, 65, 65, 62},//O
 {127, 72, 72, 72, 48},//P
 {62, 65, 69, 66, 61},//Q
 {127, 72, 76, 74, 49},//R
 {50, 73, 73, 73, 38},//S
 {64, 64, 127, 64, 64},//T
 {126, 1, 1, 1, 126},//U
 {124, 2, 1, 2, 124},//V
 {126, 1, 6, 1, 126},//W
 {99, 20, 8, 20, 99},//X
 {96, 16, 15, 16, 96},//Y
 {67, 69, 73, 81, 97},//Z
 pinMode(latchPin1, OUTPUT);
 pinMode(clockPin1, OUTPUT);
 pinMode(dataPin1, OUTPUT);
 pinMode(latchPin2, OUTPUT);
 pinMode(clockPin2, OUTPUT);
 pinMode(dataPin2, OUTPUT);
 //Clear bitmap
 for (int row = 0; row < 8; row++) {
   for (int zone = 0; zone <= maxZoneIndex; zone++) {
     bitmap[row][zone] = 0;
//FUNCTIONS
// Displays bitmap array in the matrix
void RefreshDisplay()
   int rowbit = 1 << row;
   digitalWrite(latchPin2, LOW);//Hold latchPin LOW for transmitting data
   shiftOut(dataPin2, clockPin2, MSBFIRST, rowbit);   //Transmit data
   //Start sending column bytes
   digitalWrite(latchPin1, LOW);//Hold latchPin LOW for transmitting data
   //Shift out to each matrix
   for (int zone = maxZoneIndex; zone >= 0; zone--)
     shiftOut(dataPin1, clockPin1, MSBFIRST, bitmap[row][zone]);
   //flip both latches at once to eliminate flicker
   digitalWrite(latchPin1, HIGH);//Return the latch pin 1 high to signal chip
   digitalWrite(latchPin2, HIGH);//Return the latch pin 2 high to signal chip
   //Wait
   delayMicroseconds(300);
// Converts row and colum to bitmap bit and turn it off/on
void Plot(int col, int row, bool isOn)
 int zone = col / 8;
 int colBitIndex = x % 8;
 byte colBit = 1 << colBitIndex;
 if (isOn)
   bitmap[row][zone] =  bitmap[y][zone] | colBit;
   bitmap[row][zone] =  bitmap[y][zone] & (~colBit);
// Plot each character of the message one column at a time, updated the display, shift bitmap left.
void XProcess()
 for (int charIndex=0; charIndex < (sizeof(msg)-1); charIndex++)
   int alphabetIndex = msg[charIndex] - '@';
   if (alphabetIndex < 0) alphabetIndex=0;
   //Draw one character of the message
   // Each character is 5 columns wide, loop two more times to create 2 pixel space betwen characters
   for (int col = 0; col < 7; col++)
       // Set the pixel to what the alphabet say for columns 0 thru 4, but always leave columns 5 and 6 blank.
       bool isOn = 0;
       if (col<5) isOn = bitRead( alphabets[alphabetIndex][col], 7-row ) == 1;
       Plot( numCols-1, row, isOn); //Draw on the rightmost column, the shift loop below will scroll it leftward.
     for (int refreshCount=0; refreshCount < scrollspeed; refreshCount++)
       RefreshDisplay();
     //Shift the bitmap one column to left
     for (int row=0; row<8; row++)
       for (int zone=0; zone < numZones; zone++)
         //This right shift would show as a left scroll on display because leftmost column is represented by least significant bit of the byte.
         bitmap[row][zone] = bitmap[row][zone] >> 1;
         // Shift over lowest bit from the next zone as highest bit of this zone.
         if (zone < maxZoneIndex) bitWrite(bitmap[row][zone], 7, bitRead(bitmap[row][zone+1],0));
 XProcess();
1. Connected the HC05 Module with UNO as per following diagram. The voltage divider circuit is needed as the RX-pin of HC05 is not 5V tolerant. (It is no good that you connect the HC05 Module with Hardware Serial Port which is already engaged with Serial Monitor.)
2. Is the Red-LED of the BT Module continuously blinking?
3. Have you installed a Bluetooth Terminal (BTT) in your android based smart phone?
4. Check that the smart phone has detected your BT Module. If SN is asked, enter 0000 or 1234; they usually work.
5. Connect your BTT with the BT module. Check that the RED-LED is now blinking once a while.
6. Upload the following sketch in the flash of your UNO.
#include <SoftwareSerial.h>
SoftwareSerial BTserial(2, 3); // SRX | STX
// Connect the HC-05 TX to Arduino pin 2(as SRX).
// Connect the HC-05 RX to Arduino pin 3 (as STX) through a voltage divider.
 BTserial.begin(9600);
 if (BTserial.available())
   byte x = BTserial.read();
   Serial.write(x);
 if (Serial.available())
   byte y = Serial.read();
   BTserial.write(y);
7. Check the functionality of the communication link:
BTT <----> BT <----> UNO <----> Serial Monitor
8. Add codes with your existing program to receive text message (say, Hello…!) from the Android and put it in the array named msg[].
thanx for your fast reply :slight_smile: :slight_smile:
I thought the connection between HC-05 and NANO can be done by this method and I have done this,
HC05 NANO
RX---->TX
TX---->RX(with voltage divider)
is there any way to connect the rx,tx of hc05 to nano tx,rx directly without assigning 2 and 3 pin..
if yes then what should be the code
Are using the TX and RX (Hardware UART) for the Serial Monitor? If not, how are you going to upload your sketch? If yes, the TX/RX pins are in service with the Serial Monitor/IDE. So, please go ahead with the SAURT (Software UART Port) Port; you will able to come up with a working project.
