Hi xfpd, thanks for replying
Do you think if I put the whole sketch in someone will comment on some other part of the sketch?
Here it is
#include <IRremote.h>
#include <Servo.h>
#define f 16736925 // FORWARD
#define b 16754775 // BACK
#define l 16720605 // LEFT
#define r 16761405 // RIGHT
#define s 16712445 // STOP
#define KEY1 16738455 //Line Teacking mode
#define KEY2 16750695 //Obstacles Avoidance mode
#define KEY3 16756815
#define KEY4 16724175
#define KEY5 16718055
#define KEY6 16743045
#define KEY7 16716015
#define KEY8 16726215
#define KEY9 16734885
#define KEY0 16730805
#define KEY_STAR 16728765
#define KEY_HASH 16732845
//#define RECV_PIN 12
//#define IR_RECEIVE_PIN 12
const byte IR_RECEIVE_PIN=12;
#define ECHO_PIN A4
#define TRIG_PIN A5
#define ENA 5
#define ENB 6
#define IN1 7
#define IN2 8
#define IN3 9
#define IN4 11
#define LED_Pin 13
#define LineTeacking_Pin_Right 10
#define LineTeacking_Pin_Middle 4
#define LineTeacking_Pin_Left 2
#define LineTeacking_Read_Right !digitalRead(10)
#define LineTeacking_Read_Middle !digitalRead(4)
#define LineTeacking_Read_Left !digitalRead(2)
#define carSpeed 250
Servo servo;
//put replacement for IRrecv irrecv(RECV_PIN);
//decode_results results;
unsigned long IR_PreMillis;
unsigned long LT_PreMillis;
int rightDistance = 0, leftDistance = 0, middleDistance = 0;
enum FUNCTIONMODE{
IDLE,
LineTeacking,
ObstaclesAvoidance,
Bluetooth,
IRremote
} func_mode = IDLE;
enum MOTIONMODE {
STOP,
FORWARD,
BACK,
LEFT,
RIGHT
} mov_mode = STOP;
void delays(unsigned long t) {
for(unsigned long i = 0; i < t; i++) {
getBTData();
getIRData();
delay(1);
int getDistance() {
digitalWrite(TRIG_PIN, LOW);
delayMicroseconds(2);
digitalWrite(TRIG_PIN, HIGH);
delayMicroseconds(10);
return (int)pulseIn(ECHO_PIN, HIGH) / 58;
void forward(bool debug = false){
analogWrite(ENA, carSpeed);
analogWrite(ENB, carSpeed);
digitalWrite(IN1,HIGH);
digitalWrite(IN2,LOW);
digitalWrite(IN3,LOW);
digitalWrite(IN4,HIGH);
if(debug) Serial.println("Go forward!");
void back(bool debug = false){
digitalWrite(IN1,LOW);
digitalWrite(IN2,HIGH);
digitalWrite(IN3,HIGH);
digitalWrite(IN4,LOW);
if(debug) Serial.println("Go back!");
void left(bool debug = false){
analogWrite(ENA,carSpeed);
analogWrite(ENB,carSpeed);
if(debug) Serial.println("Go left!");
void right(bool debug = false){
if(debug) Serial.println("Go right!");
void stop(bool debug = false){
digitalWrite(ENA, LOW);
digitalWrite(ENB, LOW);
if(debug) Serial.println("Stop!");
void getBTData() {
if(Serial.available()) {
switch(Serial.read()) {
case 'f': func_mode = Bluetooth; mov_mode = FORWARD; break;
case 'b': func_mode = Bluetooth; mov_mode = BACK; break;
case 'l': func_mode = Bluetooth; mov_mode = LEFT; break;
case 'r': func_mode = Bluetooth; mov_mode = RIGHT; break;
case 's': func_mode = Bluetooth; mov_mode = STOP; break;
case '1': func_mode = LineTeacking; break;
case '2': func_mode = ObstaclesAvoidance; break;
default: break;
void getIRData() {
//if (irrecv.decode(&results)){
if (IrReceiver.decode()){
//IR_PreMillis = millis();
//switch(results.value){
// int val = IrReceiver.decodedIRData.command;
unsigned long val = IrReceiver.decodedIRData.command;
// switch(decode.value);
//switch(IrReceiver.decodedIRData.command());
// case f: func_mode = IRremote; mov_mode = FORWARD; break;
// case b: func_mode = IRremote; mov_mode = BACK; break;
// case l: func_mode = IRremote; mov_mode = LEFT; break;
// case r: func_mode = IRremote; mov_mode = RIGHT; break;
// case s: func_mode = IRremote; mov_mode = STOP; break;
// case KEY1: func_mode = LineTeacking; break;
// case KEY2: func_mode = ObstaclesAvoidance; break;
// default: break;
//irrecv.resume();
// delay(1500);
//IrReceiver.resume();
void bluetooth_mode() {
if(func_mode == Bluetooth){
switch(mov_mode){
case FORWARD: forward(); break;
case BACK: back(); break;
case LEFT: left(); break;
case RIGHT: right(); break;
case STOP: stop(); break;
default: break;
void irremote_mode() {
if(func_mode == IRremote){
switch(mov_mode){
default: break;
if(millis() - IR_PreMillis > 500){
mov_mode = STOP;
void line_teacking_mode() {
if(func_mode == LineTeacking){
if(LineTeacking_Read_Middle){
forward();
LT_PreMillis = millis();
} else if(LineTeacking_Read_Right) {
right();
while(LineTeacking_Read_Right) {
getBTData();
getIRData();
} else if(LineTeacking_Read_Left) {
left();
while(LineTeacking_Read_Left) {
getBTData();
getIRData();
if(millis() - LT_PreMillis > 150){
stop();
void obstacles_avoidance_mode() {
if(func_mode == ObstaclesAvoidance){
servo.write(90);
delays(500);
middleDistance = getDistance();
if(middleDistance <= 40) {
stop();
delays(500);
servo.write(10);
delays(1000);
rightDistance = getDistance();
delays(500);
servo.write(90);
delays(1000);
servo.write(170);
delays(1000);
leftDistance = getDistance();
delays(500);
servo.write(90);
delays(1000);
if(rightDistance > leftDistance) {
right();
delays(360);
} else if(rightDistance < leftDistance) {
left();
delays(360);
} else if((rightDistance <= 40) || (leftDistance <= 40)) {
back();
delays(180);
forward();
forward();
servo.attach(3,500,2400);// 500: 0 degree 2400: 180 degree
servo.write(90);
// irrecv.enableIRIn();
IrReceiver.begin(IR_RECEIVE_PIN);//use pin 13
pinMode(ECHO_PIN, INPUT);
pinMode(TRIG_PIN, OUTPUT);
pinMode(IN1, OUTPUT);
pinMode(IN2, OUTPUT);
pinMode(IN3, OUTPUT);
pinMode(IN4, OUTPUT);
pinMode(ENA, OUTPUT);
pinMode(ENB, OUTPUT);
pinMode(LineTeacking_Pin_Right, INPUT);
pinMode(LineTeacking_Pin_Middle, INPUT);
pinMode(LineTeacking_Pin_Left, INPUT);
getBTData();
getIRData();
bluetooth_mode();
irremote_mode();
line_teacking_mode();
obstacles_avoidance_mode();
The offending bit is commented out so I can find anything else that is wrong.
