I really need your help,
Actually, I'm working on a senior design project, which is building a Tractor. I will be working on the electrical connections + the micro controller ( Adruino Uno). My electrical connections will contain the following :
- Battery 12Vdc. will be hooked up to the Adruino and transformer. I hooked it up with a transformer in order to amplify the voltage between 18 - 24 voltage to feed the load cell. I'm going to use 2 quantity of Load cell ( For your record). And Then from the load cell to a signal conditioner and then to the Microcontroller ( Adruino Uno).
?hers is the type of the load cell that i'm going to use.
?http://www.interfaceforce.com/index.php?1200-Precision-Universal-Low-Profile-™-Load-Cell-Tension-and-Compression&mod=product&show=5
?The question is: should i hook the load cell with signal conditioner first? if yes, HOW ??? despite i'm going to use TWO of Load cell?
?here is the signal conditioner that found ???
which is located in the instrument section the fifth file from the bottom of the list.
here is the model # (signal conditioner SGA AC/DC Powered)
?anyone can help me with the connection ????????????
Note: I attached a block diagram of my connection
