Apologies for the noob question.
I'm working on a project to create a volume control (with Mic Mute) which I have working on a digispark clone.
#include <TrinketHidCombo.h>
#define PIN_ENCODER_A 0
#define PIN_ENCODER_B 2
#define TRINKET_PINx PINB
#define PIN_ENCODER_SWITCH 1
static uint8_t enc_prev_pos = 0;
static uint8_t enc_flags = 0;
static char sw_was_pressed = 0;
// set pins as input with internal pull-up resistors enabled
pinMode(PIN_ENCODER_A, INPUT);
pinMode(PIN_ENCODER_B, INPUT);
digitalWrite(PIN_ENCODER_A, HIGH);
digitalWrite(PIN_ENCODER_B, HIGH);
pinMode(PIN_ENCODER_SWITCH, INPUT);
// the switch is active-high, not active-low
// since it shares the pin with Trinket's built-in LED
// the LED acts as a pull-down resistor
digitalWrite(PIN_ENCODER_SWITCH, LOW);
TrinketHidCombo.begin(); // start the USB device engine and enumerate
// get an initial reading on the encoder pins
if (digitalRead(PIN_ENCODER_A) == LOW) {
enc_prev_pos |= (1 << 0);
if (digitalRead(PIN_ENCODER_B) == LOW) {
enc_prev_pos |= (1 << 1);
int8_t enc_action = 0; // 1 or -1 if moved, sign is direction
// note: for better performance, the code will now use
// direct port access techniques
// http://www.arduino.cc/en/Reference/PortManipulation
uint8_t enc_cur_pos = 0;
// read in the encoder state first
if (bit_is_clear(TRINKET_PINx, PIN_ENCODER_A)) {
enc_cur_pos |= (1 << 0);
if (bit_is_clear(TRINKET_PINx, PIN_ENCODER_B)) {
enc_cur_pos |= (1 << 1);
// if any rotation at all
if (enc_cur_pos != enc_prev_pos)
if (enc_prev_pos == 0x00)
// this is the first edge
if (enc_cur_pos == 0x01) {
enc_flags |= (1 << 0);
else if (enc_cur_pos == 0x02) {
enc_flags |= (1 << 1);
if (enc_cur_pos == 0x03)
// this is when the encoder is in the middle of a "step"
enc_flags |= (1 << 4);
else if (enc_cur_pos == 0x00)
// this is the final edge
if (enc_prev_pos == 0x02) {
enc_flags |= (1 << 2);
else if (enc_prev_pos == 0x01) {
enc_flags |= (1 << 3);
// check the first and last edge
// or maybe one edge is missing, if missing then require the middle state
// this will reject bounces and false movements
if (bit_is_set(enc_flags, 0) && (bit_is_set(enc_flags, 2) || bit_is_set(enc_flags, 4))) {
enc_action = 1;
else if (bit_is_set(enc_flags, 2) && (bit_is_set(enc_flags, 0) || bit_is_set(enc_flags, 4))) {
enc_action = 1;
else if (bit_is_set(enc_flags, 1) && (bit_is_set(enc_flags, 3) || bit_is_set(enc_flags, 4))) {
enc_action = -1;
else if (bit_is_set(enc_flags, 3) && (bit_is_set(enc_flags, 1) || bit_is_set(enc_flags, 4))) {
enc_action = -1;
enc_flags = 0; // reset for next time
enc_prev_pos = enc_cur_pos;
if (enc_action > 0) {
TrinketHidCombo.pressMultimediaKey(MMKEY_VOL_UP);
else if (enc_action < 0) {
TrinketHidCombo.pressMultimediaKey(MMKEY_VOL_DOWN);
// remember that the switch is active-high
if (bit_is_set(TRINKET_PINx, PIN_ENCODER_SWITCH))
if (sw_was_pressed == 0) // only on initial press, so the keystroke is not repeated while the button is held down
TrinketHidCombo.pressKey(KEYCODE_MOD_LEFT_CONTROL | KEYCODE_MOD_LEFT_SHIFT, KEYCODE_M);
delay(5); // debounce delay
TrinketHidCombo.pressKey(0,0);
sw_was_pressed = 1;
if (sw_was_pressed != 0) {
sw_was_pressed = 0;
TrinketHidCombo.poll(); // check if USB needs anything done
What I want to do is also incorporate a mouse jiggler into the code to keep my screen alive.
I have seen some code which looks straight forward enough...
#include <DigiMouse.h>
void setup(){
DigiMouse.begin();
while(true) {
DigiMouse.move(2,0,0); // 2px right
DigiMouse.delay(50);
DigiMouse.move(-2,0,0); // 2px left
DigiMouse.delay(30000);
...but it runs in a while(true) loop so I'm just not sure how I can incorporate this into the volume control sketch without the loop blocking the volume control.
Any ideas?
