How can i connect 5 analog float level switch(12analog inputs) and 10 solenoids
Hey Guys,I want to do small project using arduino.i need to took data from level sensor and RTD temperature sensor and to control the 24v relay (inputs for 24v Solenoid) . i I need help for this project.
Welcome to the forum
I have moved this topic to a more suitable category
Which Arduino board do you have and exactly which sensors are you planning to use ?
Please clarify how many sensors and solenoids you have
I using arduino UNO ,and i have to take input data from level switch as analog signals (their are 12 analog inputs) .And i need to control 11 solenoid valves .
is any other module than arduino uno for my project
The reason that @UKHeliBob asked you exactly what sensors you are using is because the way you are describing them makes no sense. Switches do not output analog signals. Please post a link to the specs of these sensors.
Post a link to the specs of the solenoid valves too.
Yes. Almost any type of Arduino, Arduino compatible or other microcontroller could be used.
