I need to connect more sensor with I2C protocol, but I have only one I2C port, how I can connect more sensor in the same port?
I2C is a bus so you can connect many sensors to the same "port". Just ensure that the pull-ups are set only once per bus and that each sensor has a unique address.
Thank you, how can I set the pull ups? Do you know where I can find a practical example?
Use two resistors that match your bus’ capacity.
Do you know how to use Google? There are thousands of examples on the net.
It sound like you don’t have any experience with this stuff. Hiding all the information about your intended project doesn’t enable us to help you. Tell us what you’re trying to achieve. If you already have a plan how to achieve that, tell us that plan too. The more details you provide the more likely we’ll be able to help you.
