How can i control 2 relay in different timings with arduino and PIR sensor
My Conditions
If PIR sense Relay R1 on for 3 times with 30sec on time
if PIR sense Relay R2 on for 1 time with 30sec on time
Did you see the title of the category in which you posted ?
DO NOT CREATE TOPICS IN THIS CATEGORY
Your post has been moved to the Project Guidance category which is where you should have posted it
thank you,
Hello lenu_kannan_photography
Post your sketch, well formated, with well-tempered comments and in so called code tags "< code >" and schematic to see how we can help.
int led = 13;
int sensor = 2;
int state = LOW;
int val = 0;
pinMode(3, OUTPUT); // Relay 2
pinMode(led, OUTPUT); // Relay 1
pinMode(sensor, INPUT);
val = digitalRead(sensor);
if (val == HIGH) {
digitalWrite(led, HIGH);
delay(50);
digitalWrite(led, LOW);
delay(100);
@lenu_kannan_photography
Do you never read advice given ?
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
