How can I control 220V DC moter with pwm?
I wanna control RPM of the moter but I don't know how...
At first I planned to use 'relay module' but I heard that I can't handle the speed of moter
If you are sure that it's DC and not AC then use a transtistor with sufficiently high operating voltage (Vce, Vds). A driver and isolation circuit may be required to drive the Ib or Vgs.
But before you start killing and damaging things and yourself better search for a low-side switch module for the required voltage and current.
Not exactly the driver you need, but this will give you some insight "how to"...
(21) Modify this 5A PWM Motor Speed controller and control it with Arduino - YouTube
Welcome! Can you post a technical link to the motor, 220V is only part of it.
