I've been trying to see how I could use an app for bluetooth cars with the Uno Wifi Re2 board. I haven't found any luck with finding the board when scanning regularly. Any ideas?
If your Uno Wifi Rev 2 has a NINA module like the Nano 33 IoT, it supports BLE, not classic Bluetooth.
Do you know if there are any good controllers for android that can work with BLE?
I really do not know anything about BLE.
That said, the serial Bluetooth terminal app that I use for testing my Bluetooth (classic) devices has a Bluetooth LE function. I do not know if it will work with your Uno Wifi Rev 2. Look in the Devices menu.
The previously referenced Kai Morich's Serial Bluetooth Terminal app will indeed communicate with a BLE peripheral using the Nordic_UART Service. Indeed I have used several android BLE terminal apps and they all appear to use that service as a default.
//Nordic uart Service
#define BLE_UART_SERVICE_UUID "6E400001-B5A3-F393-E0A9-E50E24DCCA9E"
#define BLE_CHARACTERISTIC_UUID_RX "6E400002-B5A3-F393-E0A9-E50E24DCCA9E"
#define BLE_CHARACTERISTIC_UUID_TX "6E400003-B5A3-F393-E0A9-E50E24DCCA9E"
If you don't want to write peripheral code using this service, there is a library you can use to set up the UART service on a device running ArduinoBLE.h. The HardwareBLESerial library is available through the library manager.
https://github.com/Uberi/Arduino-HardwareBLESerial
I have used this library with a Nano33BLE but have no experience with the WiFi Rev2. Does the BLE use ArduinoBLE.h? If so then the library may work.
