I have a gprs module working fine but I don´t know how to control it.
I explain :
I m interesting in when the module is calling me... if I hang up the call... I want it does something...(turn on a led ... or something like that ...)...
I'm just having a similar problem. I'm not able to read AT response commands from an arduino program. It seems that the module is working properly, since it makes calls and sends sms, but I'm not able to read answers to comands like "AT+CPAS" (the answer to this command is "+CPAS: 3" in usb mode using hyperterminal if the phone is ringing) in Arduino mode. I'm using the following code in order to hang up an incomming call:
void switchModule(){
digitalWrite(onModulePin,HIGH);
delay(2000);
digitalWrite(onModulePin,LOW);
void setup(){
pinMode(led, OUTPUT);
pinMode(onModulePin, OUTPUT);
Serial.begin(115200); // the GPRS baud rate
switchModule(); // swith the module ON
delay(20000);
Serial.println("ATQ[0]");
delay(2000);
Serial.println("AT+IPR=115200");
delay(2000);
while (true)
Serial.println("AT+CPAS");
delay(2000);
if (serialReadLine(LINE_LENGTH, newLine))
if (strcmp(newLine,"+CPAS: 3")==0)
Serial.println("ATH"); // disconnect the call
Serial.println("AT*PSCPOF"); // switch the module off
