Hi. I'm looking for help with trying to figure out how to combine two separate boards nodemcu and esp32 4-relay board in one sketch for use via blynk. can anyone tell me how to? I keep getting an error saying "Compilation error: ESP8266WiFi.h: No such file or directory"~ a conflict error. because the sketch needs to include both for esp8266 and esp32, but for some reason it cant.
Here's my code:
Download latest Blynk library here:
https://github.com/blynkkk/blynk-library/releases/latest
Blynk is a platform with iOS and Android apps to control
Arduino, Raspberry Pi and the likes over the Internet.
You can easily build graphic interfaces for all your
projects by simply dragging and dropping widgets.
Downloads, docs, tutorials: http://www.blynk.cc
Sketch generator: http://examples.blynk.cc
Blynk community: http://community.blynk.cc
Follow us: http://www.fb.com/blynkapp
http://twitter.com/blynk_app
Blynk library is licensed under MIT license
This example code is in public domain.
This example runs directly on ESP32 chip.
Note: This requires ESP32 support package:
https://github.com/espressif/arduino-esp32
Please be sure to select the right ESP32 module
in the Tools -> Board menu!
Change WiFi ssid, pass, and Blynk auth token to run :)
Feel free to apply it to any other example. It's simple!
/* Comment this out to disable prints and save space */
#define BLYNK_PRINT Serial
#define RELAY_PIN_1 21
#define RELAY_PIN_2 19
#define RELAY_PIN_3 18
#define RELAY_PIN_4 5
#define LED_PIN 25
/* Fill-in your Template ID (only if using Blynk.Cloud) */
#define BLYNK_TEMPLATE_ID "TMPL2XKwz0HTx"
#define BLYNK_TEMPLATE_NAME "ESP32"
#define BLYNK_AUTH_TOKEN "StMNnw7Ijl0rL10slDDHAiScSSknvkLq"
#include <ESP8266WiFi.h>
#include <BlynkSimpleEsp8266.h>
#include <Wire.h>
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = BLYNK_AUTH_TOKEN;
// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = "Knudson111161";
char pass[] = "SEth1s1ntr0uble";
const int dcMotor1 = D1;
int slider1;
const int inPut1 = D0;
int mappedValue1=0;
const int dcMotor2 = D3;
int slider2;
const int inPut2 = D2;
int mappedValue2=0;
BLYNK_WRITE(V0)
if (param.asInt() == 1) {
digitalWrite(RELAY_PIN_1, HIGH);
Blynk.logEvent("relay_state", "RELAY_1 ON");//Sending Events
digitalWrite(RELAY_PIN_1, LOW);
Blynk.logEvent("relay_state", "RELAY_1 OFF");//Sending Events
BLYNK_WRITE(V1)
digitalWrite(RELAY_PIN_2, HIGH);
Blynk.logEvent("relay_state", "RELAY_2 ON");//Sending Events
digitalWrite(RELAY_PIN_2, LOW);
Blynk.logEvent("relay_state", "RELAY_2 OFF");//Sending Events
BLYNK_WRITE(V2)
digitalWrite(RELAY_PIN_3, HIGH);
Blynk.logEvent("relay_state", "RELAY_3 ON");//Sending Events
digitalWrite(RELAY_PIN_3, LOW);
Blynk.logEvent("relay_state", "RELAY_3 OFF");//Sending Events
BLYNK_WRITE(V3)
digitalWrite(RELAY_PIN_4, HIGH );
Blynk.logEvent("relay_state", "RELAY_4 ON");//Sending Events
digitalWrite(RELAY_PIN_4, LOW);
Blynk.logEvent("relay_state", "RELAY_4 OFF");//Sending Events
//Syncing the output state with the app at startup
BLYNK_CONNECTED()
Blynk.syncVirtual(V0); // will cause BLYNK_WRITE(V0) to be executed
Blynk.syncVirtual(V1); // will cause BLYNK_WRITE(V1) to be executed
Blynk.syncVirtual(V2); // will cause BLYNK_WRITE(V2) to be executed
Blynk.syncVirtual(V3); // will cause BLYNK_WRITE(V3) to be executed
// Debug console
pinMode(RELAY_PIN_1, OUTPUT);
pinMode(RELAY_PIN_2, OUTPUT);
pinMode(RELAY_PIN_3, OUTPUT);
pinMode(RELAY_PIN_4, OUTPUT);
pinMode(LED_PIN, OUTPUT);
delay(100);
Blynk.begin(BLYNK_AUTH_TOKEN, ssid, pass);
pinMode(dcMotor1,OUTPUT);
pinMode(inPut1, OUTPUT);
digitalWrite(inPut1, HIGH);
pinMode(dcMotor2,OUTPUT);
pinMode(inPut2, OUTPUT);
digitalWrite(inPut2, HIGH);
Blynk.run();
} // Read value from slider and set PWM duty cycle
BLYNK_WRITE(V4){
slider1 = param.asInt();
mappedValue1 = map(slider1,0,1023,0,255);
//generate PWM signal
analogWrite(dcMotor1, mappedValue1);
BLYNK_WRITE(V5){
slider2 = param.asInt();
mappedValue2 = map(slider2,0,1023,0,255);
analogWrite(dcMotor2, mappedValue2);
The BLYNK_WRITE(V4) and BLYNK_WRITE(V5) is being used by the nodemcu as sliders for pc fan speed control at 1023 variable.
Please help. Thanks. ![]()
