First, I need to know how to completely get rid of the decimals on a float or rounding the float to the nearest whole number. Second I am trying to make it so when the temperature is 55 or higher than the LED is green, and when it is less than 55 the LED is blue, but it always seems to stay on green. Here’s my code:
#include <TVout.h>
#include <fontALL.h>
#include <OneWire.h>
TVout tv;
int DS18S20_Pin = 2;
int r = 11;
int g = 12;
int b = 13;
void wb()
digitalWrite(b,HIGH);
digitalWrite(r,LOW);
digitalWrite(g,LOW);
void wg()
digitalWrite(b,LOW);
digitalWrite(g,HIGH);
void wr()
digitalWrite(r,HIGH);
OneWire ds(DS18S20_Pin);
int t = getTemp() * 9/5 + 32;
tv.begin(NTSC,120,96);
tv.select_font(font4x6);
tv.print(0,0,"Temperature Logger");
tv.print(0,7,"------------------");
tv.print(0,14,"Outside: ");
tv.print(33,14,t);
//LET THERE BE EPIC CODE!
if(t=1)
wb();
if(t=2)
wb();
if(t=3)
wb();
if(t=3)
wb();
if(t=4)
wb();
if(t=5){wb();}
if(t=6){wb();}
if(t=7){wb();}
if(t=8){wb();}
if(t=9){wb();}
if(t=10){wb();}
if(t=11){wb();}
if(t=12){wb();}
if(t=13){wb();}
if(t=14){wb();}
if(t=15){wb();}
if(t=16){wb();}
if(t=17){wb();}
if(t=18){wb();}
if(t=19){wb();}
if(t=20){wb();}
if(t=21){wb();}
if(t=22){wb();}
if(t=23){wb();}
if(t=24){wb();}
if(t=25){wb();}
if(t=26){wb();}
if(t=27){wb();}
if(t=28){wb();}
if(t=29){wb();}
if(t=30){wb();}
if(t=31){wb();}
if(t=32){wb();}
if(t=33){wb();}
if(t=34){wb();}
if(t=35){wb();}
if(t=36){wb();}
if(t=37){wb();}
if(t=38){wb();}
if(t=39){wb();}
if(t=40){wb();}
if(t=41){wb();}
if(t=42){wb();}
if(t=43){wb();}
if(t=44){wb();}
if(t=45){wb();}
if(t=46){wb();}
if(t=47){wb();}
if(t=48){wb();}
if(t=49){wb();}
if(t=50){wb();}
if(t=51){wb();}
if(t=52){wb();}
if(t=53){wb();}
if(t=54){wb();}
if(t=55){wg();}
if(t=56){wg();}
if(t=57){wg();}
if(t=58){wg();}
if(t=59){wg();}
if(t=60){wg();}
if(t=61){wg();}
if(t=62){wg();}
if(t=63){wg();}
if(t=64){wg();}
if(t=65){wg();}
if(t=66){wg();}
//nothing here
int getTemp(){
//returns the temperature from one DS18S20 in DEG Celsius
byte data[12];
byte addr[8];
if ( !ds.search(addr)) {
//no more sensors on chain, reset search
ds.reset_search();
return -1000;
if ( OneWire::crc8( addr, 7) != addr[7]) {
return -1000;
if ( addr[0] != 0x10 && addr[0] != 0x28) {
return -1000;
ds.reset();
ds.select(addr);
ds.write(0x44,1); // start conversion, with parasite power on at the end
byte present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
for (int i = 0; i < 9; i++) { // we need 9 bytes
data[i] = ds.read();
ds.reset_search();
byte MSB = data[1];
byte LSB = data[0];
int tempRead = ((MSB << 8) | LSB); //using two's compliment
int TemperatureSum = tempRead / 16;
return TemperatureSum;
Why is the LED always green?
I am using a DS18B20 temperature sensor.
