Like say i want to convert xxxxx(short) to 2 bytes xxx,yyy.
(in other words, i have a variables that is a short and i want to get the 2 bytes equivalent of it)
I'm not quite sure how to do this. Some help?
http://www.arduino.cc/en/Reference/HighByte
BTW, if you didn't have any "yyy" to begin with, this still won't work
Ah thanks!
Serial.write(highByte(val),BYTE);
Serial.write(lowByte(val),BYTE);
Gives the error
error: invalid conversion from 'uint8_t' to 'const uint8_t*
_< What am I doing wrong here?
You're trying to use a method that is supposed to be used for arrays for scalar quantities.
OH! XD My mistake. XD Thanks!
The classic answer is (short && 0xFFFF) and (short >> 8), with some consideration for signed numbers (the short should be unsigned)
Two Fs, brtech.
short myshort = 0x9A76;
byte low = (myshort & 0xFF);
byte high = (myshort >> 8) & 0xFF;
This gives low == 0x76 and high == 0x9A.
Gak! You are correct of course.
.. or no F's at all
byte low = (byte)myshort;
byte high = (byte)(myshort >> 8);
The F's are only needed if you want to convert a short hibyte/lobyte to another short (or longer). The values low/high in the above case can not hold any values beyond 8 bits so filtering higher order bits is not needed.
