how can i create menu with array values?
i want to create a user menu with deferent temperature values alarms
e.g.
user select menu (lcd)
option alarm 20c ----- option 2 alarm 18c
if user choose alarm 20c then the program run this function and ignored 18c alarm.
any help please?
What have you done so far?
#include <LiquidCrystal.h>
// Initialize the library with the numbers of the interface pins
LiquidCrystal lcd(8, 7, 6, 5, 4, 3);
//States for the menu.
int currentMenuItem = 0;
int lastState = 0;
//Set the characters and column numbers.
lcd.begin(16, 2);
//Print default title.
clearPrintTitle();
//Call the main menu.
mainMenu();
void mainMenu() {
//State = 0 every loop cycle.
int state = 0;
//Refresh the button pressed.
int x = analogRead (0);
//Set the Row 0, Col 0 position.
lcd.setCursor(0,0);
//Check analog values from LCD Keypad Shield
if (x < 100) {
//Right
} else if (x < 200) {
//Up
state = 1;
} else if (x < 400){
//Down
state = 2;
} else if (x < 600){
//Left
} else if (x < 800){
//Select
state = 3;
//If we are out of bounds on th menu then reset it.
if (currentMenuItem < 0 || currentMenuItem > 2) {
//If we have changed Index, saves re-draws.
if (state != lastState) {
if (state == 1) {
//If Up
currentMenuItem = currentMenuItem - 1;
displayMenu(currentMenuItem);
} else if (state == 2) {
//If Selected
selectMenu(currentMenuItem);
//Save the last State to compare.
lastState = state;
//Small delay
delay(5);
//Display Menu Option based on Index.
void displayMenu(int x) {
switch (x) {
case 1:
clearPrintTitle();
lcd.print ("-> Menu Option 1");
case 2:
clearPrintTitle();
lcd.print ("-> Menu Option 2");
//Print a basic header on Row 1.
void clearPrintTitle() {
lcd.clear();
lcd.setCursor(0,0);
lcd.print(" Version 1.0 ");
lcd.setCursor(0,1);
//Show the selection on Screen.
void selectMenu(int x) {
switch (x) {
case 1:
clearPrintTitle();
lcd.print ("Temperature Alarm= 20c");
//Call the function that belongs to Option 1
case 2:
clearPrintTitle();
lcd.print ("Temperature Alarm= 18c");
//Call the function that belongs to Option 2
}/quote]
If I follow your code correctly:
  1. You initialize currentMenuItem to 0 at line 7.
  2. At some point you push the "Up" button which makes the analog value be between 200 and 400, so state = 1.
  3. This causes currentMenuItem to decrement from 0 to -1. You call displayMenu(-1) which should do nothing since there's no case for -1 in its switch.
  4. The next time through mainMenu, currentMenuItem will get reset to 0 at line 48 since it's < 0.
  5. At some point you push the "Select" button which makes the analog value be between 400 and 600, so that state = 2.
  6. At this point you will call selectMenu(currentMenuItem) at line 59 with currentMenuItem = 0. This should also do nothing since there's no case for 0 in its switch.
While I'm not 100% sure about how you intend for this to work, it seems like it couldn't have wanted it to work like this. Maybe this is how you intend for it to be?
enum {menu_none, menu_20c, menu_18c, num_menus};
int currentMenuItem = menu_none;
int lastState = 0;
   lcd.begin(16, 2);
   clearPrintTitle();
  mainMenu();
void mainMenu() {
  int state = 0;
  lcd.setCursor(0,0);
  if (x < 100) {
    //Right
   //Up
    state = 1;
   //Down
    state = 2;
    //Left
    //Select
    state = 3;
      if (state == 1) {
         //If Up ,increment menu, reset when out of bounds.
         if(currentMenuItem < num_menus - 1) currentMenuItem++;
         else currentMenuItem = menu_none;
         //If Selected
      lastState = state;
   //Small delay
  delay(5);
     switch (x) {
      default:
      case menu_none:
      case menu_20c:
        clearPrintTitle();
      case menu_18c:
        clearPrintTitle();
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.setCursor(0,1);
   switch (x) {
      default:
      case menu_none:
      case menu_20c:
        clearPrintTitle();
      case menu_18c:
        clearPrintTitle();
