how can i create txt file from the date of RTC DS3231
hello all,
i want to create txt files like "01032018.txt" automatically from the date of RTC DS3231 and save using sd card module.
i try this program but it can't, in this program i use sht 11 sensor to monitor temp and humidity.
#include <SD.h>
#include <SPI.h>
#include <DS3231.h>
#include <SHT1x.h>
#define dataPin  6   //pin 10 arduino to pin 1 SHT11
#define clockPin 7   // pin 11 arduino to pin 3 clock SHT11
SHT1x sht1x(dataPin, clockPin);
DS3231 rtc(SDA,SCL);
int suhu;
int kelembaban;
File myFile;
int pinCS = 10; // Pin 10 on Arduino Uno
  rtc.begin();
  pinMode(pinCS, OUTPUT);
  // SD Card Initialization
  if (SD.begin())
    Serial.println("SD card is ready to use.");
  } else
    Serial.println("SD card initialization failed");
    return;
  rtc.begin();
suhu = sht1x.readTemperatureC();
kelembaban = sht1x.readHumidity();
Serial.print(rtc.getDOWStr());
Serial.print(",");
Serial.print(rtc.getDateStr());
Serial.print(",");
//Read time
Serial.print(rtc.getTimeStr());
Serial.print(",");
Serial.print(suhu);
Serial.print(",");
Serial.println(kelembaban);
String filename=String(rtc.getDateStr() + ".txt");
char str[16] = {0};
filename.toCharArray(str,16);
myFile = SD.open(str, FILE_WRITE);
if (myFile) {
myFile.print(rtc.getDOWStr());
myFile.print(",");
myFile.print(rtc.getDateStr());
myFile.print(",");
//Read time
myFile.print(rtc.getTimeStr());
myFile.print(",");
myFile.print(suhu);
myFile.print(",");
myFile.println(kelembaban);
    myFile.close(); // close the file
  // if the file didn't open, print an error:
  else {
    Serial.println("error opening test.txt");
  delay(3000);
thank you for your help :slight_smile:
It can't what? Can't tie your shoes?
What IS in str when that code executes?
omg sorry. the error is "invalid operands of types 'char*' and 'const char [5]' to binary 'operator+'"
anindyadwi:
That is only part of the error message. The rest includes the file name and the line number where that is happening.
Apparently, rtc.getDateStr() returns a char * - a pointer to a char array. You are then trying to increment that pointer by ".txt", which makes no sense at all.
If you insist on pissing away memory using Strings,
String filename = rtc.getDateStr();
filename += ".txt";
