How can I disable Arduino's internal pull-ups, to use Sparkfun 6DOF IMU?
Hello,
I'm a Newbie trying to set up an Arduin Nano v3 with the Sparkfun IMU 6DOF ITG3200/ADXL345 and I'm following this example by Oscar Cornelis Rutger den Uijl.
http://www.den-uijl.nl/gyro.html by
How can I disable the pull-up in the wire.h library? In the sixth paragraph, Mr. Uijl mentions adjusting the twi.c file, but I can't find it on my system. I'm using Arduino 1.0 on OSX10.4.
Any help would be greatly appreciated, I'm still very new to Arduino.
Thanks!
6DOF IMU - http://www.active-robots.com/sensors/motion-inertia-1/imu-digital-combo-board-6-dof-itg3200-adxl345.html
The twi code is in /libraries/Wire/utility/twi.c (where depends on your install)
Near the start there are these lines:
  digitalWrite(SDA, 1);
  digitalWrite(SCL, 1);
All you need to do AFAICT (no need to change the library code) is after every call to TwoWire.begin() do this:
  digitalWrite(SDA, LOW);
  digitalWrite(SCL, LOW);
to disable the pullups
robotturtle:
On my 10.7 (and Arduino 1.0) open Applications, right click on the Arduino.app an select "Show Package Contents", then go to Contents/Resources/Java/libraries/Wire/utility/
