I check in ways to implement multi threathing in arduino, i also try using the library TimerOne but it doesn't seem to work, what i'm trying to make is an arduino aplication than, every time a certain ammount of time pass, it pop an item from the stack, and, between that times, the aplication allow me to add items to the stack, both process working in paralel of course.
The items poped and pushed are numbers.
Here is the code:
#include <TimerOne.h>
#include <QueueList.h>
#include <StackList.h>
const uint16_t NOTE_B0 = 31;
const uint16_t NOTE_C1 = 33;
const uint16_t NOTE_CS1 = 35;
const uint16_t NOTE_D1 = 37;
const uint16_t NOTE_DS1 = 39;
const uint16_t NOTE_E1 = 41;
const uint16_t NOTE_F1 = 44;
const uint16_t NOTE_FS1 = 46;
const uint16_t NOTE_G1 = 49;
const uint16_t NOTE_GS1 = 52;
const uint16_t NOTE_A1 = 55;
const uint16_t NOTE_AS1 = 58;
const uint16_t NOTE_B1 = 62;
const uint16_t NOTE_C2 = 65;
const uint16_t NOTE_CS2 = 69;
const uint16_t NOTE_D2 = 73;
const uint16_t NOTE_DS2 = 78;
const uint16_t NOTE_E2 = 82;
const uint16_t NOTE_F2 = 87;
const uint16_t NOTE_FS2 = 93;
const uint16_t NOTE_G2 = 98;
const uint16_t NOTE_GS2 = 104;
const uint16_t NOTE_A2 = 110;
const uint16_t NOTE_AS2 = 117;
const uint16_t NOTE_B2 = 123;
const uint16_t NOTE_C3 = 131;
const uint16_t NOTE_CS3 = 139;
const uint16_t NOTE_D3 = 147;
const uint16_t NOTE_DS3 = 156;
const uint16_t NOTE_E3 = 165;
const uint16_t NOTE_F3 = 175;
const uint16_t NOTE_FS3 = 185;
const uint16_t NOTE_G3 = 196;
const uint16_t NOTE_GS3 = 208;
const uint16_t NOTE_A3 = 220;
const uint16_t NOTE_AS3 = 233;
const uint16_t NOTE_B3 = 247;
const uint16_t NOTE_C4 = 262;
const uint16_t NOTE_CS4 = 277;
const uint16_t NOTE_D4 = 294;
const uint16_t NOTE_DS4 = 311;
const uint16_t NOTE_E4 = 330;
const uint16_t NOTE_F4 = 349;
const uint16_t NOTE_FS4 = 370;
const uint16_t NOTE_G4 = 392;
const uint16_t NOTE_GS4 = 415;
const uint16_t NOTE_A4 = 440;
const uint16_t NOTE_AS4 = 466;
const uint16_t NOTE_B4 = 494;
const uint16_t NOTE_C5 = 523;
const uint16_t NOTE_CS5 = 554;
const uint16_t NOTE_D5 = 587;
const uint16_t NOTE_DS5 = 622;
const uint16_t NOTE_E5 = 659;
const uint16_t NOTE_F5 = 698;
const uint16_t NOTE_FS5 = 740;
const uint16_t NOTE_G5 = 784;
const uint16_t NOTE_GS5 = 831;
const uint16_t NOTE_A5 = 880;
const uint16_t NOTE_AS5 = 932;
const uint16_t NOTE_B5 = 988;
const uint16_t NOTE_C6 = 1047;
const uint16_t NOTE_CS6 = 1109;
const uint16_t NOTE_D6 = 1175;
const uint16_t NOTE_DS6 = 1245;
const uint16_t NOTE_E6 = 1319;
const uint16_t NOTE_F6 = 1397;
const uint16_t NOTE_FS6 = 1480;
const uint16_t NOTE_G6 = 1568;
const uint16_t NOTE_GS6 = 1661;
const uint16_t NOTE_A6 = 1760;
const uint16_t NOTE_AS6 = 1865;
const uint16_t NOTE_B6 = 1976;
const uint16_t NOTE_C7 = 2093;
const uint16_t NOTE_CS7 = 2217;
const uint16_t NOTE_D7 = 2349;
const uint16_t NOTE_DS7 = 2489;
const uint16_t NOTE_E7 = 2637;
const uint16_t NOTE_F7 = 2794;
const uint16_t NOTE_FS7 = 2960;
const uint16_t NOTE_G7 = 3136;
const uint16_t NOTE_GS7 = 3322;
const uint16_t NOTE_A7 = 3520;
const uint16_t NOTE_AS7 = 3729;
const uint16_t NOTE_B7 = 3951;
const uint16_t NOTE_C8 = 4186;
const uint16_t NOTE_CS8 = 4435;
const uint16_t NOTE_D8 = 4699;
const uint16_t NOTE_DS8 = 4978;
uint16_t Notas[] =
NOTE_B0
, NOTE_C1
, NOTE_CS1
, NOTE_D1
, NOTE_DS1
, NOTE_E1
, NOTE_F1
, NOTE_FS1
, NOTE_G1
, NOTE_GS1
, NOTE_A1
, NOTE_AS1
, NOTE_B1
, NOTE_C2
, NOTE_CS2
, NOTE_D2
, NOTE_DS2
, NOTE_E2
, NOTE_F2
, NOTE_FS2
, NOTE_G2
, NOTE_GS2
, NOTE_A2
, NOTE_AS2
, NOTE_B2
, NOTE_C3
, NOTE_CS3
, NOTE_D3
, NOTE_DS3
, NOTE_E3
, NOTE_F3
, NOTE_FS3
, NOTE_G3
, NOTE_GS3
, NOTE_A3
, NOTE_AS3
, NOTE_B3
, NOTE_C4
, NOTE_CS4
, NOTE_D4
, NOTE_DS4
, NOTE_E4
, NOTE_F4
, NOTE_FS4
, NOTE_G4
, NOTE_GS4
, NOTE_A4
, NOTE_AS4
, NOTE_B4
, NOTE_C5
, NOTE_CS5
, NOTE_D5
, NOTE_DS5
, NOTE_E5
, NOTE_F5
, NOTE_FS5
, NOTE_G5
, NOTE_GS5
, NOTE_A5
, NOTE_AS5
, NOTE_B5
, NOTE_C6
, NOTE_CS6
, NOTE_D6
, NOTE_DS6
, NOTE_E6
, NOTE_F6
, NOTE_FS6
, NOTE_G6
, NOTE_GS6
, NOTE_A6
, NOTE_AS6
, NOTE_B6
, NOTE_C7
, NOTE_CS7
, NOTE_D7
, NOTE_DS7
, NOTE_E7
, NOTE_F7
, NOTE_FS7
, NOTE_G7
, NOTE_GS7
, NOTE_A7
, NOTE_AS7
, NOTE_B7
, NOTE_C8
, NOTE_CS8
, NOTE_D8
, NOTE_DS8
QueueList<int> KeyNotesNode = QueueList<int>();
StackList<int> StackNote = StackList<int>();
char receivedChar1 = '<';
char receivedChar2 = '<';
char receivedChar[] = {receivedChar1, receivedChar2};
int TempInt = 0;
bool newData = false;
bool itPopUp = false;
int modality = 0;
if(modality == 0){
Serial.println("Ingrese el tipo de funcionalidad deseada");
Serial.println("1.- Constructor de canciones en tonos");
Serial.println("2.- Juego de imposicion musical");
Timer1.initialize(150000);
Timer1.attachInterrupt( setForPop );
//Checa y controla la recepcion de los char a traves de la consola de arduino
if (Serial.available())
receiveChar();
showReceivedChar();
// . . . Here is some code to process the reception of data from serialData . . .
// From somewhere here start the loop
// . . . LOOPED . . .
//Here is used the data
if(modality == 1){
//This option doesn't matter
else if(modality == 2){
StackNote.push( (((int)(receivedChar[0]-'0'))*10)+((int)receivedChar[1]-'0') );
Serial.println("Agregado receivedChar exitosamente a la Pila");
Serial.print("Tamano Total Lista: ");
Serial.println(StackNote.count());
Serial.print("Dato:");
Serial.println( (((int)(receivedChar[0]-'0'))*10)+((int)receivedChar[1]-'0') );
Serial.print("Dato(get):");
receivedChar[0] = '<';
receivedChar[1] = '<';
//Run and show the data on the stack
if(modality == 1)
if(itPopUp){ //With this variable i want to control when it is show, this code is inside loop()
Serial.print("Reproducido con exito la nota: "); //se escribe 'éxito' pero la consola no acepta tildes, que se arrepienta :P
TempInt = StackNote.pop();
Serial.println(TempInt);
tone(9,Notas[((int)TempInt)],500);
} //Here the loop() end
//This function i want to run it asyncronously
void setForPop(){
if(itPopUp){
itPopUp = !itPopUp;
else{
itPopUp = !itPopUp;
Please, feel free to ask anything
Thanks in advance
