How can I dynamicly allocate the site of an array (int8_t)
Hello,
I a trying to limit the amount of data sent to the server with LoRa.
I declare a variable this way:
uint8_t payload[51];
memset(payload,'\0',payloadSize);
But when I have some unactive sensor, I only use 24 space
In toher word, when I merge the data into payload and I print the length
       Si.sprint(F("Payload len: "),2); Si.sprintln(pl,2);
        int ps = sizeof(payload);
        Si.sprint(F("Payload size: "),2); Si.sprintln(ps,2);
I got this value
Payload len: 24
Payload size: 51
any the payload value is:
61 32 38 62 39 36 34 63 34 36 64 32 35 65 31 30 30 68 30 6B 34 32 39 2C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
As you can see, there is a lot of 00, I would like to eliminate.
My idea is to realocate the size of payload to 24 (or to the result of strlen(payload);
I guess we can reallocate the size of a int8_t? that’s right?
Orwould it better to copy payload to a new variable
int8_t new_payload[strlen(payload)];
new_payload = payload;
Smaller packs fit in the big buffer, just send less bytes.
You gave only snippets of the problem, so I can not tell you more.
Dear Whandall
It's what I am doing, but as payload is initialized with 51
and then I clear is with 0
the zeros you can see here
are not values that I sent.
The values that I sent is
and the last 2C, could be removed
try to only print the amount of data received, not the whole buffer
For text, use strlen() instead of sizeof()
