How can I Fix a Static IP Address on ESP-01 and ESP-01S
Hi All,
I have been working around with all kind of ESP8266 devices and most of my work includes NodeMCU and D1 Mini boards. Of which I have been satisfied with all the way.
But, When I uploaded a NodeMCU and D1 mini 100% working sketch on the ESP-01S board - I could not make it sign up for the Static IP I set it for - It always uses DHCP. That part I need to do since I want to use it for IoT and I need the device to keep the IP Provided to it As I have done with the NodeMCU and D1 Min Boards.
My Includes:
#include <Arduino.h>
#include <ESP8266WiFi.h>
#include <ESP8266WiFiMulti.h>
#include <WebSocketsClient.h>
#include <ArduinoJson.h>
#include <StreamString.h>
ESP8266WiFiMulti WiFiMulti;
WebSocketsClient webSocket;
WiFiClient client;
  //Static IP address configuration
This is the Settings that I have put at the TOP of the sketch .ino file.
  IPAddress ip(192, 168, 0, 24); //ESP static ip
  IPAddress gateway(192, 168, 0, 1);   //IP Address of your WiFi Router (Gateway)
  IPAddress subnet(255, 255, 255, 0);  //Subnet mask
  IPAddress dns(8, 8, 8, 8);  //DNS
  const char* deviceName = "duino";
  //On board LED Connected to GPIO2
  #define LED 2
  //SSID and Password of your WiFi router
  const char* ssid = "MySSID";
  const char* password = "MyPass";
Then I have added my functions and all the other settings I needed for the IoT device to work, of which it works 100% But uses a DHCP IP and Not the fixed IP I provided. It gets 192.168.0.150 or any other IP besides the 192.168.0.24 that I set up.
  pinMode(LED,OUTPUT);
  digitalWrite(LED,LOW);
  delay(2000);
  digitalWrite(LED,HIGH);
  WiFi.hostname(deviceName);      // DHCP Hostname
  // HERE IS THE SETUP I AM TALKING ABOUT: If you use .config before .begin it should use it, correct?
  WiFi.config(ip, subnet, gateway, dns);
  WiFi.begin(ssid, password);
  Serial.println("");
  Serial.println("WiFi connected. ");
  Serial.print("Hostname: ");
  Serial.println(WiFi.hostname());
  Serial.print("IP address: ");
// Here I am getting 0.0.0.0 and if I add a delay I get the 192.168.0.150 IP
No matter how hard I try to make it get the Static IP - it fails all the time. But when I use the SAME CODE on NodeMCU and D1 Mini Boards - it works 100% and they get the static IP I provide them. And yes I have given each one a different IP so there are NO IP collisions at all.
I would be happy if you could assist me in understanding what I am doing wrong here - is it me? Is it the ESP-01S board - is it ESP8266Wifi Library? :confused:
I would be happy to be able to keep a Static IP on this board since I have them already planned to be on each of my IoT devices.
Would be happy if you could assist me on that :frowning: :frowning:
Thank you!
Aryeduino.
because it already connected to WiFi at that time. try WiFi.setAutoConnect(false)
Thanks,
Yes, I have tried that and I am getting:
exit status 1
'WiFi' does not name a type
Any idea why?
thanks
I have managed to figure out why I got the error - But, I still have the device auto connect through DHCP even with the WiFi.setAutoConnect(false).
Not sure what is forcing it to connect through the DHCP?
Please assist, thanks.
SOLVED! thanks
aryeduino:
SOLVED! thanks
could you post how you solved it, to help others in future may be
Sure,
Here is the code I have used - and I could make the ESP-01S to get a Static IP Address:
// config static IP
  WiFi.setAutoConnect(false);   // Not working by its own
  WiFi.disconnect();  //Prevent connecting to wifi based on previous configuration
  IPAddress ip(192, 168, 0, 25);
  Serial.print(F("Setting static ip to : ")); // Adding these lines to see the IP that the device is getting
  Serial.println(ip);
  WiFi.config(ip, gateway, subnet, dns);
//  WiFi.config(ip, subnet, gateway, dns);
Hope that would help :slight_smile:
Thanks for your assistance.
Aryeduino.
