how can i fix The system cannot find the file specified
i had an ardoino for a long time but is doing probloms now i even reinstalled the softwore but i cant fix this i get this massege every time
ארדואינו:1.6.12 (Windows 10), לוח:“Arduino/Genuino Uno”
Sketch uses 704 bytes (2%) of program storage space. Maximum is 32,256 bytes.
משתנים גלובלים משתמשים ב-9 בייט (0%) של זיכרון דינמי, משאיר 2,039 בייט לאחסון משתנים מקומיים. מרב המקום הוא 2,048 בייטים.
java.io.IOException: Cannot run program “REMOVE/bin/avrdude”: CreateProcess error=2, The system cannot find the file specified
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1048)
at processing.app.helpers.ProcessUtils.exec(ProcessUtils.java:26)
at cc.arduino.packages.Uploader.executeUploadCommand(Uploader.java:129)
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:206)
at cc.arduino.UploaderUtils.upload(UploaderUtils.java:78)
at processing.app.SketchController.upload(SketchController.java:707)
at processing.app.SketchController.exportApplet(SketchController.java:680)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2176)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.io.IOException: CreateProcess error=2, The system cannot find the file specified
at java.lang.ProcessImpl.create(Native Method)
at java.lang.ProcessImpl.(ProcessImpl.java:386)
at java.lang.ProcessImpl.start(ProcessImpl.java:137)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1029)
… 8 more
שגיאה במהלך העלאת סקיצה
“Show verbose output during compilation”
option enabled in File → Preferences.
how can i fix this ?
I also have the same situation. The error is :
Arduino: 1.6.12 (Windows 10), Board: “Arduino/Genuino Uno”
Sketch uses 444 bytes (1%) of program storage space. Maximum is 32,256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
REMOVE/bin/avrdude -C___REMOVE___/etc/avrdude.conf -v -patmega328p -carduino -PCOM5 -b115200 -D -Uflash:w:C:\Users\KARANB~1\AppData\Local\Temp\arduino_build_49680/sketch_oct09a.ino.hex:i
… 8 more
An error occurred while uploading the sketch
My Arduino board worked on previous Arduino IDE 1.6.8. On installing 1.6.12 My Wemos board was not recognized and this was fixed by cloning into hardware directory from GitHub for esp8266.
Wemos issue is resolved but this one is pending.
Help required.
Regards
Also have the same issue. Started a thread but no replies so far.
http://forum.arduino.cc/index.php?topic=428399.0
Must be a bug with 1.6.12
I have same problem :(
THOR-00: I have same problem :(
Given the age of this thread, how about you start a new one giving details on exactly the problem you are facing?
Hello,
Did you already fix it?
I'm having the same problem.
BramDelft:
Hello,
I’m having the same problem.
When you encounter an error you’ll see a button on the right side of the orange bar “Copy error messages”. Click that button. Paste the error in a message here USING CODE TAGS (</> button on the toolbar).
Arduino: 1.8.5 (Windows 10), Board: "Adafruit Feather M0"
Sketch uses 9600 bytes (3%) of program storage space. Maximum is 262144 bytes.
java.io.IOException: Cannot run program "{runtime.tools.bossac-1.7.0.path}/bossac": CreateProcess error=2, The system cannot find the file specified
	at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:207)
	at processing.app.SketchController.upload(SketchController.java:713)
	at processing.app.SketchController.exportApplet(SketchController.java:686)
	at processing.app.Editor$DefaultExportHandler.run(Editor.java:2168)
	at java.lang.Thread.run(Thread.java:748)
	at java.lang.ProcessImpl.<init>(ProcessImpl.java:386)
	... 8 more
option enabled in File -> Preferences.
Did you install Arduino SAMD Boards? If not, try this:
  • Tools > Board > Boards Manager
  • Wait for downloads to finish
  • Click on "Arduino SAMD Boards"
  • Click "Install"
  • Wait for download to finish
  • Click "Close"
  • Try uploading again.
Yes, I already did. The strange thing is that everything was working yesterday and today suddenly this error occurred. I have no idea what the cause is
I just installed the newest versions of both Adafruit SAMD Boards and Arduino SAMD Boards and I can't reproduce the problem.
I think it's time to take some drastic action. Be aware this is somewhat advanced and will remove all boards you have installed via Boards Manager:
  • Click the link on the line following File > Preferences > More preferences can be edited directly in the file. This will open the Arduino15 (or similar name depending on OS) folder.
  • Delete all files and folders under the Arduino15 folder except for preferences.txt. Please be very careful when deleting things from your computer. When in doubt, back up!
  • Restart the Arduino IDE
  • Use Boards Manager to reinstall Arduino SAMD Boards and Adafruit SAMD Boards
  • Cross your fingers
  • Try an upload
Unfortunately it didn't work... I'm so frustrated. Just no idea what to do
Please do this:
  • File > Preferences > Show verbose output during: > compilation (check) > OK
  • Sketch > Verify/Compile
  • After the compilation fails you’ll see a button on the right side of the orange bar “Copy error messages”. Click that button.
  • Paste the error messages in a reply here USING CODE TAGS (</> button on the toolbar).
