How can I fix this strange rollback?
I had programming to use LiquidCrystal_I2C, and integrated find I2C address and use LCD. So I use class, but it has something wrong. I made just one object, but the program loop back a specific part
Here is my code
//main.ino
#include "LCD.h"
LCD_CUSTOM LCD;
//LCD.h
#ifndef LCDLibrary_H
#define LCDLibrary_H
#include "Arduino.h"
#include <Wire.h>
class LCD_CUSTOM {
  public:
    uint8_t address;
    LCD_CUSTOM() {
      address = 0;
      init();
      running();
  private:
    void init();
    void running();
#endif
// LCD.cpp
#include "LCD.h"
void LCD_CUSTOM::init() {
  Wire.begin();
  Serial.println("\n--------------------I2C Scanner--------------------");
  Serial.println(LCD_CUSTOM::address);
  byte error = 0;
  int nDevices;
  Serial.println("active");    // loop back point.
  for(LCD_CUSTOM::address = 1; LCD_CUSTOM::address < 127; LCD_CUSTOM::address++)
    Wire.beginTransmission(LCD_CUSTOM::address);
    error = Wire.endTransmission();
    if(error == 0)
      Serial.print("I2C device found at :address 0x");
      if(LCD_CUSTOM::address < 16)
        Serial.println(" !");
      Serial.print(LCD_CUSTOM::address, HEX);
    else if(error==4) {
      Serial.print("Unknow error at address 0x");
      if(LCD_CUSTOM::address<16)
        Serial.print("0");
      Serial.println(LCD_CUSTOM::address, HEX);
  if(LCD_CUSTOM::address == 127)
    Serial.println("No I2C devices found\n");
    Serial.println("done\n");
  Serial.println("\n--------------------I2C Scanner End--------------------");
  Serial.println("Init complete. Running LCD");
void LCD_CUSTOM::running() {
  LiquidCrystal_I2C lcd(address, 16, 2);
  lcd.begin();
  lcd.print("Hello, World!");
Make the following changes:
  LCD.init();
  LiquidCrystal_I2C lcd(LCD_CUSTOM::address, 16, 2); // Use LCD_CUSTOM::address
  lcd.begin();
// LCD.h
#include <Wire.h>
class LCD_CUSTOM {
  public:
    uint8_t address;
    LCD_CUSTOM();
    void init();
    void running();
#endif
// LCD.cpp
#include "LCD.h"
LCD_CUSTOM::LCD_CUSTOM() {
  address = 0;
  Wire.begin();
  Serial.println(address);
  byte error = 0;
  int nDevices;
  for(address = 1; address < 127; address++) {
    Wire.beginTransmission(address);
    if (error == 0) {
      Serial.print("I2C device found at address 0x");
      if (address < 16)
        Serial.print("0");
      Serial.println(address, HEX);
    } else if (error == 4) {
      Serial.print("Unknown error at address 0x");
      if (address < 16)
        Serial.print("0");
  if (address == 127)
  lcd.begin();
#include "LCD.h"
LCD_CUSTOM LCD;
  LCD.init();
  LCD.running();
It works! Thank you so much.
But why did this happen?
Your loop was void. And also you did not initialize the LCD in your setup function. These were the main issues.
I see. Thank you for reply!
